Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Ultimate Racing UICP 2 piece install
Old Dec 19, 2009 | 03:19 AM
Methodical4u's Avatar
Well, it was 3:30 am and snowing as you can see... I wasn't tired and got the pipe in a few days ago and decided to put it on.... here's how it goes...
The snow..
The heater that kept me semi warm while doing this little project..
we lift the hood and there are the plastic clips that hold the large plastic piece are removed by pulling up on the tip of them, when they pop out pull them the rest of the way out, careful not to break them.
these unscrew and then the piece they were screwed into pops out... be gentle.
All of the clamps are 10mm... the bolts holding the UICP in place are 12mm.
it's not super easy to get to, but it can be done with patience... and small hands
loosening the clamps
with the 12 mm bolts out, pull up a little to get the pipe loose... I took out the whole pipe in 1 piece pretty much, but you may choose to do it in pieces. Either is fine.
the new pieces... sturdy feeling and just overall feel like quality.
this pic shows just how tight these clamps are put on from the factory, so the easiest way to get it off of the innercooler is to loosen the bolts as much as possible and remove them, so the rubber pipe crap comes off easier.. it's still a bit of a chore though, so expect to pull pretty hard, and make sure you move around a bit to help you out.
loosening the clamp at the turbo
whole part removed
first I decided to do the part near the turbo... the silicone slips over the metal much easier than the originals came off, the new size is also 9/32'... slide the small end over the outlet and tighten both new clamps, ensure they are nice and tight.
in place
other end ready to be attached to the pipe from the IC.
before I found my 1/4 ratchet I used this little screw driver to tighten down the clamp at the IC without the pipe first.
pipe now set into place... don't tighten it yet just to make sure you can join the 2 pipes together without a problem...
as you can see... there is plenty of pipe to join them up
join it up in the middle, tighten it down and then tighten the other clamp from the IC...
check all your connections, start the car and listen for any hissing or any other signs of boost leaks... if everything looks and sounds good... you're all ready to go! Good luck, hope this helped someone out!
Old Dec 19, 2009 | 09:40 AM
mlomker's Avatar
Definitely easier to do when you upgrade the fmic. The snow looks awesome...time for some parking-lot mayhem!
Old Dec 19, 2009 | 05:27 PM
I would, but no snow tires and no salt around my car lol.
Old Dec 23, 2009 | 09:15 AM
BlitzX's Avatar
I ordered this along with the full exhaust. Can't wait to fit it . thanks for the writeup.
Old Dec 24, 2009 | 07:03 PM
ApexSilverXGSR's Avatar
I was actually looking for this write-up too. Great job man and merry christmas.
Old Dec 25, 2009 | 02:37 PM
JED_POLAND's Avatar
Great job!
Will the UICP fit the ETS 3.5" intercooler?
Old Dec 26, 2009 | 07:25 AM
wiretap's Avatar
I just did an intake and UICP install yesterday on my X. I didn't heat up the garage and it was about 30 degrees out. LOL, **** those factory couplings are hard to get apart. My hands and arms are so tore up. I went out there thinking it was going to be an easy job by just popping off the old tubes and pop on the new ones. I found that coupling on top of the intercooler was a little easier to do if you unbolt the horn, and take off those bolts holding the front bumper on. It gives you a little more room to fit your hands down in there.
Old Dec 26, 2009 | 11:24 AM
boostin20's Avatar
methodical4u, I pm'ed you
Old Jan 12, 2010 | 06:30 PM
superlemonevo's Avatar
between the turbo and the uicp, how to ensure there is no leaking there? should we put some sealant there or using gasket?
Old Jan 13, 2010 | 08:45 AM
EvoIXMR's Avatar
People use hairgel or hairspray to prevent leaking. You coat it with hairgel or spray, slide pipes on and tighten clamps and let it dry up. T-bolt clamps are definitely a must to prevent leaks.
That being said, only real way to tell if you have leaks is a boost leak tester!
Methodical - We meet again . Still waiting for my TXS catback after I got Evo VIII one sent to me You are like me - no snow or salt around my Ebo...
Does the cover fit back on with the pipe? Also you gonna get the UR UICP and does it work with stock airbox?
Old Jan 13, 2010 | 08:50 AM
yeah, I put the cover back on and it seems to fit fine on mine. The pipe is a bit bigger, but you really don't notice.
I'm not quite sure what you mean about it working with the stock air box? I have a green filter drop in in the car now.
Old Jan 13, 2010 | 01:57 PM
EvoIXMR's Avatar
Sorry, I asked above....but I will re-phrase
Also you gonna get the UR UICP (the other pipe from IC to TB) and does it work with stock airbox?
Old Jan 18, 2010 | 04:02 PM
nlp187's Avatar
Nice write up. I'll be doing this soon!
Old Jan 22, 2010 | 01:39 AM
henryDgreat's Avatar
very easy to do with your guide! thanks
this is for me sometime in the future lol
would you know if X turbo parts bolt-on directly on lancer 09?
can i reuse pipings, turbo and manifold?
Old May 3, 2010 | 03:23 PM
wrxnevox's Avatar
nice write up
