oil and fuel pressure gauge install?
Make sure to measure clearance of the oil filter first. IIRC, there should be enough, but if you're using an especially long/tall oil filter + that adapter, it might not all fit under the cover.
On 4B11 engine it seems there's not that place, so you have to use the adpater and on the adapter vibrations are much less than directly on the block.
CeliOnce
Jun 22, 2016 08:16 AM
CeliOnce
Jun 18, 2016 12:06 PM
[WTB] AEM 50PSI boost gauge
needsboost
Mar 7, 2016 10:18 AM
