Pads and Rotors How-to
I checked for that but that wasn't my case. I took the car for an alignment this morning and the guy had a hell of a time lining up the rear end. after about 40 minutes he finally got it stable and straight. However, when we went for the test drive the right rear made an insane wobbling/scraping sound. Threw it back on the lift to take the wheel off to check the brakes but the wheel studs were spinning in place so the four lug nuts weren't coming off....the wheel lock came free though thankfully. No idea what happened. I think one stud spun, then the others slowly came loose in the few miles I put on the car. Gotta drill out the nits from the front now
everyone else I hope you learn from this. Even reinstalling the wheels with a torque stick, this occurred. DO NOT use an impact gun...at least this happened to my own car and not a customers
everyone else I hope you learn from this. Even reinstalling the wheels with a torque stick, this occurred. DO NOT use an impact gun...at least this happened to my own car and not a customersIf really nasty, and you do have a good 6pt socket that has the whole bolt covered, just get a 2' steel pipe, "cheater", to help you get more torque. I'd say it's just some rust from salt on the road. Make sure too you're not trying to tighten instead of loosen. Coming from the opposite side it's not uncommon to get reversed.
edit: You might need to raise your vehicle a bit higher. I had not enough room the first time or two and needed to elevate the whole thing to get a better grab on the 1/2" breaker bar.
With a little practice, I've gotten all four rotors and pads changed in a little over an hour end-to-end, including jack and tire time. (- hand tools only, outdoors, on gravel driveway)
NEVER EVER let anyone put your wheels on except yourself -- or a racing shop. A torque wrench is required on the Evo or you'll warp your rotors, or worse as you point out. FWIW, those studs are easy as hell to remove and replace. $3 ea at OReilly. Beat them out with a hammer (b i g g e r is better) and buy a lug that's open to pull the stud through. You shouldn't have any problems getting out broken ones using the same technique. I had that happen after an HPDE and someone named Steve over torqued his lugnutz. Lesson learned, cheaply for me as I DIY.
Nice write up on changing rotors/pads out.
-B
But to do it "right" and keep it trackable, do put at least an annual brake fluid flush into your plans.
Great write up! I've done breaks on other vehicles (mostly SUVs) but this will be helpful when I tackle my Evo!
Question - how do you know WHEN to replace your pads? Is there a visual inspection rod or something that I can see and determine how much time I have left on the brakes? They just started squeaking the other day..
Many thanks!
Many thanks!
Many thanks!
Many thanks!
Replacement at anything less than 1/8" or just over that is good time for the new ones. I'm guessing no track time as of yet?
Thanks Steve! Yes no track time yet (and only 14k miles) and I keep the car (and rims/rotors) pretty clean.. typically washing everything every 2 weeks or so in the summer and maybe once a month during the winters. I've got some great anti-carbon stuff I use at work to clean the rims/rotors with so they're kept pretty nice.
I just wasn't sure if there was an easy inspection pin or something that could be measured to tell wear.
