how do you install SS brakelines on GSR?
I hate to bother you with a really dumb question..so here goes. I was wondering how you install the SS brakes lines on a X. Obviously I know I need a box wrench or two to remove the lines, however there are a few variables I need covered. 1)How should I drain the system without damaging the paint on the calipers. 2) When bleeding the brake calipers what order should I do it and do I need to bleed something else besides the calipers considering the clutch and brake system share a reservoir. Thanks in advance!!!
Also..I saw the write-up from joe250..but...seems like something is missing...
i wanna know how to change it too because im planning to change it.
i just saw some old posts yesterday. the order should be "the evo x order should be driver rear, passenger front, passenger rear, driver front"
i don't know if it's right tho, so please check it before go it.
Thanks for the advice friend. but..I've driven with the SS lines..just never installed them..I was running axxiss pads with SS lines on another setup...I noticed a much solid pedal feel..but nothing dramatic..however I'll still keep what you said in mind..being winter and all..
smached=smashed?
What was he doing Autocrossing that he smashed up the car and how exactly did it relate to the SS brake lines?
I'm curious about the story and the details, being an amateur Autocrosser!
Thanks.
beetle is correct. I put SS brakelines on mine and thats how I did it. Start with the Passenger Rear. Than the Driver Rear, followed by the Passenger Front and do the Driver Front last. Remember, when you bleed the system that there is 2 bleeder valves on each calipers. Bleed the front one first(the one you can see). Than bleed the back one(the one on the back side of the caliper). As for draining it, there is no need to. I just used a small rubber plug to keep it from leaking every where. Check the reservoir after you bleed each caliper, to make sure to doesnt go below the "MIN" line or you will have to do the bleeding process over. As for the paint on the calipers. I just spraied them with brake cleaner and have had no problems with the paint fading/chipped or anything and its been over 2 months since I went to SS brakelines.
I installed the SS brakelines..and sure enough beetle was right. I found the info on a service manual pdf that I downloaded some time ago. I also bled the clutch since it shares a reservoir with the brake fluid...most people don't mention it..but I think that's the last one you should do. Everything turned out ok..drove it..noticed the difference right away..I more solid pedal and less pedal effort. I'm thinking of doing a right up..but...the lines are pretty straight forward..the bleeding on the other hand..
I did it on my gsr after watching this video. Almost the same, at least the principles are the same. Make sure you bleed afterwords. There is the brake bleeding video you can watch too. The video is great.
http://videos.hspn.com/?videoid=45&catid=14
Not sure what service manuals you guys are looking at, but the two I have for the 08 X state Driver rear, passenger front, passenger rear, driver front.
_____2___3
FRONT
_____4___1
_____2___3
FRONT
_____4___1
___ 3____1
Front
____4___2
...if I'm not mistaken..We are just pointing out that the X is not like the VIII and IX...esp..with how joe250 writes it up.
also, it says bleed the outside screw first, then inside.
btw, i installed AMS lines, but someone told me they would be the same as other popular brands since they all come from the same manufacturer... and you'll notice that the nut holding the line to the hardline is not going to fit the stock bracket on the car. it's very slightly larger than the bracket. i dunno what you guys did, but i actually used a dremel to shave the inside of the bracket slightly, then it was a perfect fit.
