~ How to install the Devils Own H2O / Meth injection ~
I recently switched over from my AEM kit to this on and I really love the quality of it as well as the simplicity. It might be something for those of you debating a Meth kit to look at
https://docs.google.com/fileview?id=...YTcyOTkz&hl=en
I know the company that makes this will be coming out with a lot of new options for kits and some bad *** tanks. If its all half as good as this Meth kit I maybe picking up some new parts.
Parts were a little on the cheap side and after a bit made me nervous
More metal on this kit for the important parts and don't have to worry about failing plastic ones. I was actually just looking at an install of a "Cooling Mist" kit and it looks like a lot the same parts as the Devil's Own.
Cost is about the same but quality is miles apart, plus I like the looks of the Devils controller also. The Devils Own pump is a variable you can vary between 150-250psi so if your using X nozzle and need just a hair more or less don't jump up or down a full nozzle size just adjust the pump for tuning.
One thing I love is the ability to use your stock wiper fluid bottle, its 1.5 gallon or so vs the AEM 1 gallon. (Got annoying trying to fill it.
Oh yeah also AMERICAN company with American parts with techs easy to get a hold of when you need help.
Almost forgot the controller also can be hooked to the MAP sensor wire thats a big plus
bambooi
14
May 26, 2009 11:05 AM
shunderwunder
11
Nov 3, 2007 11:55 PM
335i, devils, devilsown, dsm, eclipse, evo, injection, install, installation, installing, kit, kits, meth, mitsubishi, nozzle
