Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How do you install hid bulbs without moving the bumper
Old Apr 9, 2010 | 07:21 PM
FireRed1210's Avatar
I read online that you can install hid bulbs without moving the bumper.
Im stuck and I dont know what to do
Old Apr 9, 2010 | 08:26 PM
Talon_66's Avatar
Remove the bumper. Problem solved.
Old Apr 9, 2010 | 08:38 PM
Maxmumboom's Avatar
the bumper comes off easily
Old Apr 9, 2010 | 09:01 PM
icethug's Avatar
I done it without removing the bumper. I had to squeeze my hand through fender well and got bunch of scratches on my hand but it's doable. If I had to do it again, I would remove the bumper......
Old Apr 9, 2010 | 09:17 PM
tephra's Avatar
taking off the bumper is very very easy...
the trickies bit is peeling the bumper away from the car near the fenders... just take your time
Old Apr 23, 2010 | 11:53 PM
NRG's Avatar
NRG
no need to remove the bumper...I can swap out the bulb in under 5 minutes...unbolt the smaller of the two relay box and move it aside on the driver side and unhook the coolant reservoir on the passenger side. Once thats done, you can put your hands in there...Passenger side is a bit tighter though...
Old Apr 24, 2010 | 06:19 PM
initial_d2k's Avatar
look in the Owner's Manual ..
Old May 1, 2010 | 06:37 PM
wrxnevox's Avatar
i want to see this one
Old May 28, 2010 | 12:16 PM
Lancer09mx's Avatar
I did it without removing the bumper once, DON'T DO THAT !
removing the front bumper is really esay and if you do that you can easy install in a perfect location the ballast of the kit.
Old May 28, 2010 | 01:00 PM
NRG's Avatar
NRG
Nah...no need to remove the bumper...
Old May 28, 2010 | 07:37 PM
gripbox's Avatar
take it to a car shop...that way you dont have to install or do anything...
Old May 31, 2010 | 09:43 AM
Guru's Avatar
I did both without removing bumper. As NRG said you'll need 10mm rachet to get off the relay box on driver's side. Move coolant resovoir. It's tight but certainly doable. I run Philips 6000K Ultinon bulbs. Much better than OEM.
Old May 31, 2010 | 09:51 AM
NRG's Avatar
NRG
I also run the Philips Ultinon...NOT CHEAP!!! So be careful putting it in...
It only goes in one way CORRECTLY. There is a notch that aligns to the housing. Make sure the angle is correct as it is easy to put it in at the wrong angle and be able to secure the fold over latch. The way I made it easier is I take a picture of it after I install it to see if it is aligned to the notch and is angled correctly. You won't be able to see it as your head won't fit in that space, so use a camera.
If the angle is wrong, you will know right away when you turn on the HID, as the light output will be dimmed as it is pointing somewhere else inside the housing...
Old Jun 1, 2010 | 08:33 AM
kdiggz's Avatar
all cars ive owned required you to remove the bumper. the first few times i tried without it and later on i saw how much easier it really was to just remove it
Old Jun 2, 2010 | 03:03 PM
XBoost's Avatar
I got super slim ballasts and was able to mount them on both fender wells under the hood. My car was brand new at the time the last thing I wanted to do is start taking it apart. Ill see if I can snap a couple of pics n post them.
