Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
aluminum ebrake
Old Apr 10, 2010 | 11:51 AM
JACOB3RD's Avatar
aluminum ebrake
2010 evo x gsr sss
how do i remove the leather e brake cover to install the aluminum e brake cover?
Old Apr 10, 2010 | 07:01 PM
monkey_187's Avatar
Check to see if it has a tiny screw under it, I have the aluminum handle and it has a tiny screw under it.
Old Apr 14, 2010 | 10:28 PM
alex3dworld's Avatar
i did it a couple of days ago.
if the one that you have now is the stock plastic one, just pull it hard, try to do it rotating a little bit the handle in both directions. the OEM instructions recomend to use a heat gun a little to heat up the plastic. i didn't need it.
to install the aluminum one, as monkey say, there is a little screw under the handle, don't screw it to hard or it will get stuck, this little screw is just for guide. then install the handle and put the other two screws in the handle.
sullysnet
Jun 22, 2016 07:21 AM
lancer0220
Sep 17, 2015 10:10 PM
Gamble
Aug 23, 2015 06:06 AM
JerseyEvox
24
Nov 14, 2012 09:26 AM
gokusupersaiyen
Lancer Engine Tech
Apr 19, 2003 11:31 PM
