Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Dynamat? Doors or Trunk?
Old Mar 13, 2012 | 08:40 PM
Inprogress's Avatar
Anyone have a DIY for installing sound deadening material in the doors, trunk, or the roof of our cars? How complicated could either of those installs be? I'm afraid of removing pnaels and breaking clips, so I'm wondering if I can do this myself
Old Mar 13, 2012 | 10:07 PM
AFD's Avatar
AFD
For removing the door panels, you can follow one of these how-to's..
https://www.evolutionm.net/forums/ev...our-evo-x.html
https://www.evolutionm.net/forums/ev...im-pieces.html
If you're deadening the doors for car audio purposes, you'll probably want to seal them first by using either the available OEM hole covers, sheet metal or a stiff sound deadener to close up the larger openings (or a combination).
Found a list of part #'s for the hole covers (all four doors) & any needed screws or clips (think the 2 part numbers with dashes are Alpine spacers)..
5759A012
5759A011
5759A013 ×2
MU670034 ×8
MF453031 ×8
MU480032 ×8
5729A-25
5729A-26
5729A024
5729A023
MU670034 ×6
MF453031 ×12
MU480032 ×12
Here are pics showing examples of sealed Evo X doors..
Good luck
Old Mar 14, 2012 | 07:34 AM
Inprogress's Avatar
Couldn't I just dynamat the entire door and in turn have the holes filled by the dynamat?
Old Mar 14, 2012 | 08:57 AM
Inprogress's Avatar
What is the inner and outer panel?
Old Mar 14, 2012 | 09:35 AM
AFD's Avatar
AFD
Yeah, that would probably work as well. Think it's just more ideal to use a stiffer material to fill in any of the larger openings before applying dynamat.
If that was from one of the how-tos, it's probably referring to one side or the other of the door panel you'd need to remove (the part you see when you're inside the car, that has the door handle and window buttons).
Old Mar 21, 2012 | 06:13 PM
BIGLOU58's Avatar
is there a noticible difference? never installed before
Old Mar 22, 2012 | 09:05 PM
vtecless's Avatar
bump, i'm curious as well
Old Mar 29, 2012 | 01:26 PM
timereaper's Avatar
Not only does this cut off noticable outside noise, the speakers playing off the dynamatted doors sound more solid.
I know cause I first dynamated the doors, then went on to dynamat the trunk and floors later. The subwoofer was then hitting much harder and the exhaust noise from the muffler was drowned out further. The sound stage was much clearer by this time without outside noise interfering.
I have a 2010 lancer sportback, similar doors.
Old Jul 22, 2012 | 02:06 PM
Inprogress's Avatar
I just got my doors done, inner and outer skin, and it is a noticeable difference. The music is more direct and enjoyable and no rattling from my sub either, sounds like the sub hits tighter too. I plan on doing my floor and rough next.
Has anyone used Dynamat Hoodliner? It can reduce engine noise and heat, any thoughts?
Old Jul 23, 2012 | 06:19 AM
timereaper's Avatar
Not a worthwhile investment, sound from engine will escape other places, and really doesn't help with noise in cabin. Any sound it dampens outside the vehicle will get lost to the sounds of other vehicles outside.
Old Jul 23, 2012 | 06:24 AM
FJF's Avatar
FJF
Before you do that, click on the link below and read every page. You'll know more about this subject, and how to go about the project intelligently, than 99.99% of the folks who discuss it:
www.sounddeadenershowdown.com
Old Jul 23, 2012 | 12:49 PM
SamsonEvoX's Avatar
^ Felix, that is a great site to learn about sound deadening.
Old Jul 23, 2012 | 08:22 PM
Buru_EvoX's Avatar
Thanks for the info FJF!
Old Jul 24, 2012 | 05:06 AM
beantown's Avatar
Good info!
Old Jul 24, 2012 | 01:09 PM
flipflop's Avatar
This is why I love evom! Thanks for the info. I'm now ready to tackle this project. For those who contributed, let me know when you are in SF cause 's on me!
