HELP: CLeaning Bronze VOLKS
i think i might just have to try it..
I bough a wax right now.. nothing
i bough a polish right now.. tried it on the side of a spoke.... nothing.
peanut butter it is.. i wont use junky tho..lol
I use a mild wheel acid on my Advans and on my daily (Yukon on chrome 24's) when I get spots like that... or be cheap and make your own... going back to the vinegar theory http://www.ehow.com/how_7636169_clea...oy-wheels.html
I would try Brasso.
Brasso can be used on anything metal to clean and polish to a high shine without damaging or pitting the surface, and without a thick waxy thick buildup. From coin collections to photo frames, you can use Brasso on a wide assortment of household items.
It's pretty much safe on everything:
Send a email to Volk and ask them what they recommend.
can someone please say if this PB worked or not or the best thing to use. i used maguire wheel cleaner and it messed up my CE's and now has like white chalk stain allover and it's not coming off! I'm so pissed and just want to know what to do to fix my wheels does the PB trick work????!!!!
So i tried the PB and nothing worked.
I was at as gasoline station about 2 months ago. And some guy came up to me about this car stuff that helps clean your car without water.. blah blah blah.. it would help keep the car clean for 3 months.. Bull crap is what i thought. but he put some off that stuff on my Audi's rims which had alot of junk and bam.. it came right off and it actually cleaned the rim whell. its some type of spray on wax.. i wanted to buy some to put it on my rims.. but i didnt have money on hand, and i was skeptical about giving out my card information. I went back later on that day and he was gone.Now i say about a month ago..they were selling that stuff near my house. went over to fill up my tank on my evo. Some other guy started to want to sell the stuff.. i just told him " let me try it on my rims on a small section, if it cleans that white chalk crap then ill buy it".. It took it off. my rims look brand fu**ing new.. its called FW1
Link http://www.youtube.com/results?hl=en...-8&sa=N&tab=wy
its actually pretty good.. i wouldnt use it to wash my car as stated cause i like to use water and soap. But when i get build up on my ww x on the back of the car due to running a test pipe. it takes off all the junk on my trunk.. It actually cleaned my door handle entry wear it was all scratched up.. i have since only used this to clean my rims.. wait i take that back.. i clean my rims.. with soap and water.. maybe some mcguires spray... let them dry.. then i apply this..
u apply it to the rim.. let it sit. .. buff it with a micro fiber towel with the wax on.. clean the rim with the same towel.. and with a new towel that has no wax.. rebuff it.. and eeverything is gone.. takes about 5-7 mins a rims..
i usally apply to all the rims at the same time after the wash to let the wax sit for a while.. then i just make sure every single spoke has the wax.. slight buff the rim with the OG towel.. and after all the wax is gone... use the other towel as i stated before to buff it slightly.. and .. ur rims will look like you once had them!
