Carbon fiber trunk install help?????
I am installing a VIS Demon(Do-Luck) carbon fiber trunk and wanted to know if i needed to change the springs in the trunk as well or if i can lessen the power to the springs somehow any help would be appreciated thanks!
If you used to have the high wing try using 1 damper. As soon as you release it from the lever under the seat the trunk will come up flying. The best IMO is get the damper from a regular lancer with or without the low wing or the damper with an evo with the low wing. These dampers ARE different as they are not as strong as the dampers from trunks with high wings.
-lay towel across rear glass to set each side of trunk lid on as you take it off
-unbolt one side, set it on the towel
-unbolt other side, set it on the towel
-take old trunk lid and set aside
-revers process with new trunk
You can remove the trunk lift arms by using a little flathead screwdriver. There's a black clip on the bottom of them. When you pry it backwards, it pops off and allows you to slip the lift rod off of the coupler.
I have the VIS Demon as well, and I only use one of the lift arms now
they are excellent. I've had two.
perfect, no gaps.
if you get a "VIS Trunk" and it has gaps or finish issues, it is fake. Always buy from an authorized VIS Racing dealer or from VIS themselves.
perfect, no gaps.
Kevin_White19
May 12, 2017 07:03 PM
GSX_TO_EVO
Jul 26, 2016 11:13 AM
WTB[Pacific NW]: looking for carbonfiber trunk and hood
cmiller10
Jul 2, 2016 08:57 AM
