Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Help cleaning up black trim on exterior
Old Mar 26, 2014 | 09:54 AM
boostedlife's Avatar
What's up guys? Just got my Evo last weekend and noticed some white substance on the mirror trim and the rear air dam that I believe could be just wax residue from when it was cleaned. Just wondering what you guys recommend using to clean this off and restore the black plastic parts to their original luster. Thanks!
Old Mar 26, 2014 | 11:04 AM
evo_production's Avatar
just wipe it down or do a light scrub with soap and water and then i like to use tire shine to bring it back to shining. if not then just rinse and keep clean
Old Mar 29, 2014 | 07:50 PM
Ok i tried the soap and water thing today and it didn't do anything. I couldn't get the white residue off at all. I didn't try tire shine but i figured it needed to be cleaned first.
Old Mar 29, 2014 | 07:57 PM
ak47po's Avatar
http://www.adamspolishes.com/p-512-a...-dressing.aspx
Old Mar 29, 2014 | 09:53 PM
vi3tprydefolyfe's Avatar
Just buff over it with back to black I personally use the turtle wax kind
Old Mar 30, 2014 | 11:22 AM
Good suggestions, thanks guys!
Old Feb 19, 2015 | 08:28 PM
e85_evodiction's Avatar
good stuff
Old Jul 12, 2015 | 04:49 AM
Evodetailer123's Avatar
I'll share some detailers secrets, use the magic eraser with an all purpose cleaner or degreaser. If no luck which usually doesn't happen use a stiff bristle brush something like you would use to scrub carpets with the degreaser. It'll come off. Do this then apply your black to black or dressing of choice. Never apply a dressing over dirt.
Old Jul 12, 2015 | 08:18 AM
e_kobz's Avatar
Mothers back to black trim restorer
Old Jul 12, 2015 | 11:41 AM
splattj's Avatar
This. And a toothbrush to get down in the texture and break up the dried wax.
Believe it or not, peanut butter works well to get rid of dried wax but it's such a pain to clean in and of itself, it's not worth the bother.
Old Aug 27, 2015 | 01:28 PM
commbubba19's Avatar
2nd for peanut butter.
Just use an old t-shirt or mf towel. A little goes a long way. Work it into the plastic and then buff off. the oils soak into the plastic and bring it back to life along with removing old wax.
Old Aug 28, 2015 | 04:14 AM
The Phantom's Avatar
ive done a couple of different products and found a couple to work well. i did the peanut butter trick also and it works surprisingly well also. just make sure not to get a glob in a panel crack are flies and stuff will come around lol
Old Aug 28, 2015 | 11:53 AM
steve0677's Avatar
vegetable oil FTW
Old Aug 28, 2015 | 12:10 PM
kaj's Avatar
kaj
old wax is quite the nemesis. that's never fun. i used to know a guy that used transmission fluid on his trim pieces. basically, anything petroleum should help with old plastic/rubber pieces. i use Stoner Trim Shine. not that it's better than any of the other suggestions here, but it's in a convenient spray bottle. it's just easier for me to use.
Old Oct 27, 2015 | 12:43 PM
jessemoody's Avatar
yeah magic eraser is abrasive so remember to never let it hit painted surfaces
