Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Quick Tip For Transmission Removal
Old Apr 8, 2014 | 07:29 PM
IRPerformance's Avatar
Drop the subframe. The fsm doesnt call for it but it makes the job so much easier.
Old Sep 20, 2014 | 06:45 PM
Mudkicker's Avatar
I couldn't get the trani back in without dropping the subframe. I tried several times.
Old Sep 21, 2014 | 04:52 PM
It takes an extra few minutes and makes the job a ton easier. We always do it.
Old Sep 23, 2014 | 05:07 PM
twinturbogreg's Avatar
Define "drop the subframe"?
Old Sep 23, 2014 | 07:17 PM
Subframe that sits under the engine/trans and holds the steering rack. Unbolt the rack from the subframe, support the rack with some bungie cords, and drop down the subframe. It makes the job so much easier.
Old Sep 24, 2014 | 04:20 AM
Mudkicker's Avatar
Your rack and pinion steering is mounted to the subframe. Remove 1 small heat shield to access 1 of 3 rack and pinion bolts. unbolt rack from subframe and 2 bolts securing steer line. Now you can remove 4 bolts securing subframe and move out of the way. Don't need to completely remove.
Old Sep 24, 2014 | 11:49 AM
Yea I should have clarified. I drop it down and let it hang. You don't need to completely remove it from the car.
SmurfZilla
Aug 16, 2015 03:50 PM
samj601
Nov 21, 2014 08:01 AM
