Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How To Install FUSE into a Non FUSE lancer
Old Mar 8, 2017 | 10:17 AM
Ude Lose's Avatar
Will the BT module - Part # 8785A045
From a 2012 evolution work as well?
Old Mar 9, 2017 | 10:45 AM
beetle_orange's Avatar
I am not positive but I guess as long as it uses the newer socket it should work.
Old Mar 9, 2017 | 01:01 PM
Ude Lose's Avatar
I ordered it today.
I'm fairly positive it is just a newer version.
Once I get all the parts in the mail and do the install I'll report back.
Old Mar 10, 2017 | 09:48 AM
Where did u order?
Old Mar 10, 2017 | 07:00 PM
Ude Lose's Avatar
Ordered off of eBay and also got 2 oem pig tails to go with it and also the usb wire that installs into the oem location.
Old Mar 11, 2017 | 06:06 AM
Can I buy the pigtails
Old Mar 11, 2017 | 06:21 AM
Ude Lose's Avatar
I'm going to use 1 of them for sure. The second one I'm not sure about.
If I don't wind up using it I'll contact you.
They are rather easy to come by.
Old Mar 13, 2017 | 08:04 AM
aclymer's Avatar
Post
Originally Posted by Ude Lose
I actually called about those items today.
The connector is on back order until July and the pins can be ordered in smaller quantities if you place lp after the description.
If you have any more questions just call them.
I actually asked for a free sample directly from TE. I had to register an account, I used my work address, and create a project title. They sent them next day, it was nice.
I'm an engineer and am comfortable ordering engineering samples like this. If you are not comfortable with that methode, just search around a bit. I found the connector in-stock at one website and the pins in-stock at another.
Mouser.com
Digikey.com
OnlineComponents.com will have more 3/17/17
Newark.com
Powerandsignal.com has them in-stock
Old Mar 13, 2017 | 08:10 AM
aclymer's Avatar
I finally got this mod to work, but had some trouble getting there. I have one note for everyone:
The pin numbers are all based on the FEMALE side of the connection. Don't use the pin numbers on the connector. If you are looking at the female side of the connection, the count starts top - right to left, then down a row, and right to left again. So this means the male connector (the one you have to move all the wires to) is read from the back as if it was plugged into the female connector.
Good luck! It works great!
PS Pull you radio fuse or battery cable before messing with the plug. I blew my fuse when the red/white wire touched ground. OOPS
Old Mar 13, 2017 | 08:12 AM
aclymer's Avatar
Yes. I would suggest getting the newer part numbers as they can be updated with the latest firmware for better connections. I got the 025 model and it has SW 8.0.0, so my BT Audio cuts out from time to time and I don't know if it can read my iPhone's music over USB.
Old Mar 13, 2017 | 10:53 AM
Ude Lose's Avatar
Awesome thanks for the update.
I am going to try to attempt mine this weekend.
Have any pics of the wiring pin outs?
I don't intend to cut my factory Bluetooth connector but rather just remove the pins/wires and reinstall them in the new 28 pin connector.
Old Mar 14, 2017 | 05:33 AM
Pretty sure if you have he right tool this would be the better route, taking the pins off but it was a pain in the *** for me so I just cut them off. What tool did u get?
Old Mar 14, 2017 | 07:40 AM
Ude Lose's Avatar
I popped up the plastic lock going across the bottom side of the plug and used a sewing needle to free the metal pins from the front.
The first one was a bit tough until you understand how to release them but then it's very easy.
Old Mar 14, 2017 | 08:25 AM
aclymer's Avatar
I didn't take any pictures (sorry), but just remember that the pin #s are L->R looking at the FEMALE socket. I wired mine with the pin #s reversed the first time, luckily it didn't ruin my BT module. You'll need 22 AWG wire (~0.3 - 0.5 mm^2) for the three new wires. On my plug the Black/White wire is the "Mass" wire in the pdf from page 1.
I also took the time to remove the pins, just popped the lock bar up and used a flattened needle in the small slot above the pin to release the pins. It's well worth the effort. Be careful not to ground the Red/White wire unless you like replacing fuses.
Old Mar 14, 2017 | 09:41 AM
Ude Lose's Avatar
On my pigtail I have right now I have.
28 pin connector.
Slot 28 is solid green with silver dots.
Slot 27 is pink / yellow stripe
Slot 26 solid black
Slot 21 brown / grey dots
Slot 20 solid green.
Slot 16 solid purple.
Slot 15 red / white stripe.
Slot 14 solid red
Slot 13 red/white stripe
Slot 7 yellow
Slot 1 black with red stripe.
This male pig tail may have come out of a newer outlander so I am hoping that the wires used are similar to the other pig tail that came out of a 2012 Evo X that should be here this week.
I will compare them when it arrives.
