converting my Lancer evolution MR to GSR Manual transmission
me? If i wanted to re-wire the entire car wiring harness. Instead, i have an evo x gsr ECU with an evo x gsr wiring harness that works in unison with the car wiring harness because of ingenuity and gets what i wanted done
He does not own his own shop. All work was done at/by PRS in Orlando. He is now in Texas (I believe that SSP has the car, now). I haven't spoken to the owner in a long time (he is a friend of a friend). I wanted so badly for that swap to work out for him, but I never saw it come to a conclusion.
the mechanical part is the easy part, flywheel, clutch, gearbox and sifter will do the job.
the hard part is the electrical part, I should need a complete loom , as for the ECU a programmable ECU (motic, JIMS, ...etc would do the job, may be I would need a ACD?? but I think with the new motic M800 you wont neet to change the ACD??
I cant see where is the problem ??
WTF... I typed a LONG post with your part numbers and references.. and this ***** deleted it.. gRRR... Ill repost when I compile my list again...
it is possible... for about 5-7k depending if you have the trans services.. I have been building a parts pile for a little bit due to a budget...
Im been thinking of the idea of converting my Lancer evolution MR to GSR Manual transmission; please provide me a full price quote on the conversion parts cost (i.e. manual transmission , pedals , most importantly electrical wiring for GSR And etc for everything else has to come for the conversion to work) and the overall cost
kyle wade
Lancer Tranny/Drivetrain Tech
Oct 21, 2014 04:24 AM
D3souz4
Dec 7, 2012 05:15 AM
