The Ultimate Aggressive Wheel Thread... Evo X Style
Old Dec 29, 2010 | 09:26 PM
  #2101
Tantrum X's Avatar
^ It's 18x10.5 +15
Originally Posted by blincoln423
What lip is that and how much did it run you?, I really like it, it's subtle but there and can fit the rexspeed carbon fiber foglight ducts which is a plus
It's Do Luck front lip. If you want subtle, the JDM fog deletes complements this front lip perfectly.
Old Dec 30, 2010 | 01:08 AM
  #2102
JiNSOO619's Avatar
Originally Posted by MarcusDubya77
I am new to the forums, and have been reading the threads, but can't find an answer. There is a member running 18x9.5 +20 Rota Grid (Gold) and 265.35.18 Hankook Ventus EVO Tires. Does anyone know if this requires rolling, or any rubbing issues? I still haven't picked mine up. Have about 6 months left here in Japan before I PCS. Any help would be great.
I'm not running Rotas, but these are 18x9.5 +12s, only small rubbing I have is the front fender liner at full lock, when I'm reversing out or something. Haven't rolled any of the fenders, and I'm lowered on Eibach Pro Kit.
Front camber -2.3
Rear camber -2
Rear might need a little more camber, just by .5
But I haven't had any rubbing issues.
Since you're +8 offset higher, I'm sure you're in the safe zone. My friend has 18x9.5 +22 Rotas w/ 265/35s as well, no problems with him either. Running on Swift Springs, with similar camber settings. He has a little less camber than I do.
Hope this answers your question
Old Dec 30, 2010 | 07:58 AM
  #2103
slo4g63's Avatar
Sounds exactly like what I ran into, I saw a DIY using a heat gun and a screw driver to help mold the fender liner, but after a slip and near miss of the oil cooler, I found an easier way.
Find the fatest socket you have available and a heat gun. Turn the wheel to the point where it rubs the fender liner.
Squeeze the socket in between tire and fender liner, the grooves/folds in the liner helps hold it in place.
Use heat gun to .... heat up the fender liner haha. Then afterwards, use some cold water on the liner (away from heat gun )
No more rubbing on fender liner.
Old Dec 31, 2010 | 01:04 AM
  #2104
JiNSOO619's Avatar
Nice, thanks for the tip. Now I just need a heat gun
I wonder if patience + a blow dryer would work... Lol!
Old Dec 31, 2010 | 08:14 PM
  #2105
bpjr07's Avatar
sick!!
Old Jan 1, 2011 | 04:09 PM
  #2106
journeymansteve's Avatar
Working at McDonnell Douglas doing composite mfr, yes, we used blow dryers in a pinch instead of heat guns. Get one that is 1500w or greater. Fan is actually not important, would rather have a slow one than fast, with high watts. And patience. You can actually get things hotter with the blow dryer than the heat gun, according to our quality inspection guys. Just have to lean it just so, and let the heat build up in a spot.
Old Jan 2, 2011 | 12:32 AM
  #2107
MarcusDubya77's Avatar
Front camber -2.3
Rear camber -2
Thanks for that help. I am still shopping around, and just am excited about getting back to the good ole US. Any rubbing if I go 18x10 +20 on 275's. Anyone running that set up with pics?
Old Jan 2, 2011 | 08:24 AM
  #2108
Evo Tengoku's Avatar
Here's 18x10+20 with 275 tires:
More pics here https://www.evolutionm.net/forums/ev...ml#post7154063
Old Jan 7, 2011 | 06:48 AM
  #2109
bigjay10's Avatar
Man I'm jealous of these sexy beast. How can my llittle 2010 gts sportback compare to these monsters. Like a Care Bear trying to fight Bigfoot. 2 years and I'll be trading for a used X. dammit!
Old Jan 7, 2011 | 07:00 AM
  #2110
Cesarn2928's Avatar
Front camber -2.3
Rear camber -2
those wheels are soo ****in sexy!
Old Jan 15, 2011 | 11:06 AM
  #2111
bigjay10's Avatar
I noticed noone likes wheels with a chrome lip. Whats up with that? Is it ricing?
Old Jan 15, 2011 | 11:38 AM
  #2112
Fergy33WF's Avatar
I don't think that is the case... Chrome lips just seem to make your wheels look a size or two smaller. They look nice but make your 18" wheels look like 17"s.
Old Jan 15, 2011 | 11:42 AM
  #2113
bigjay10's Avatar
Holy shrinking wheels, Batman. I didn't even think about that. Now I wish I hadn't asked cause I got 18" Drag 19s. DRAT!!
Old Jan 15, 2011 | 02:53 PM
  #2114
Fittest's Avatar
In my opinion (and what I notice in SoCal, one of the largest import scenes in the country), dark wheels with chrome lips are played out.
I mean, it's common to see a soccer mom driving a Benz SUV or the CEO rolling in an Audi still sporting that combo. Most of the cars I see with that wheel design are now Neon SRT-4s and early 2000 3-series.
Time for a new fad (and gawd I'm hoping the dark headlight/taillight scene goes soon as well--ghetto).
Old Jan 15, 2011 | 04:09 PM
  #2115
_Chris_'s Avatar
