The Ultimate Aggressive Wheel Thread... Evo X Style
Old Jun 27, 2013 | 11:54 AM
  #3916
MR Dan's Avatar
Originally Posted by evoXnsx209
heres some more pics =]
Very clean....please post frontal and side shots
Old Jun 27, 2013 | 12:59 PM
  #3917
evoXnsx209's Avatar
Originally Posted by nonschlont
SEXY!!! ^
thanks!
Old Jun 27, 2013 | 01:00 PM
  #3918
evoXnsx209's Avatar
thanks! and yes will post some more pics soon!
Old Jun 27, 2013 | 09:52 PM
  #3919
NaDeAu's Avatar
Work Emotion 11R 18 x 9.5 +12 with Bridgestone RE-11 275/35/18
Old Jun 27, 2013 | 09:55 PM
  #3920
RallySport Direct's Avatar
Silver Sponsor
^ Those look really good! great color combo.
Kyle
Old Jun 27, 2013 | 11:53 PM
  #3921
eSco tomE's Avatar
Originally Posted by RallySport Direct
Love this thread Lots of very clean cars, proper stance and great fitting wheels
Setup is 18x10.5 + 22 offset Rays 57 Xtremes with a custom Candy Red Finish.
Tires are 275/35R18 Falken Azenis RT615K
-Dallin
i am looking to do this same set up. did you have to roll your rear fenders? if so, was it mild and did you have to do the heat gun mod to the front?
Old Jun 28, 2013 | 12:38 AM
  #3922
SD_Lurker's Avatar
Ot
Old Jun 28, 2013 | 04:19 AM
  #3923
awdxftw's Avatar
Veteran: Army
Ot
Old Jun 28, 2013 | 08:27 AM
  #3924
Silver Sponsor
Its a great setup so you will like it
Yes the rear fenders are a mild roll. You do want to use a heat guy when doing it to help soften the paint and this will help to prevent it from cracking.
Originally Posted by SD_Lurker
Of course he has to roll the fenders. Almost any 10.5 wheel with a offset of +30 or less will need to be rolled.
I would say with even some 9.5" wide wheels running a low offset, a wider tire and stock alignment you would want to consider rolling the rear fenders even. I test fitted another set of wheel that were 18x9.5 +22 offset and with the factory alignment specs if there was a 265 or larger tire it probably would have rubbed.
Originally Posted by awdxftw
^not if you run 265/35's and don't have a crazy drop. Why be a douche canoe when you haven't done your homework????
eSco tomE he'd def had to roll AND use a heat gun, i've actually never heard of anyone rolling fenders without one good luck
The setup on this car is 18x10.5 +22 offset on a 275/35 tire. Alignment is only slightly more aggressive than stock with -1.8 F and -1.0 R.
If the car was lower a bit more aggressive alignment may be needed to not rub.
There will be a lot of different variables though so do some research on what you are wanting to achieve. Wheel size, offset, brake clearance, tires size, ride height and alignment.
I am personally not a big fan of having my cars slammed with a lot of camber. I like to be able to drive my car into most placed, parking lots, driveways and not go through expensive tires every year
I like the functionality of this car as this car is daily driven.
When it comes down to it, it's your car so do what you want
-Dallin
Old Jun 28, 2013 | 11:51 AM
  #3925
SD_Lurker's Avatar
Ot
Old Jun 28, 2013 | 12:53 PM
  #3926
Black&Boostin's Avatar
Real fly set up! Must be a ***** to clean those wheels .. but id say its worth it
Old Jun 28, 2013 | 12:58 PM
  #3927
awdxftw's Avatar
Veteran: Army
Ot
Old Jun 28, 2013 | 02:04 PM
  #3928
evoXnsx209's Avatar
lol! it is a pain to keep these clean, and yes it is worth it!
Old Jun 28, 2013 | 02:25 PM
  #3929
SD_Lurker's Avatar
Ot
Old Jun 29, 2013 | 02:36 AM
  #3930
JNguyen228's Avatar
Bye bye ccw's!! Time for a new set up soon
