My Defi gauge install!
Old May 26, 2008 | 07:22 PM
Tunerhead's Avatar
Great install.....gives me some ideals on where to install mine when I get one.
Old May 26, 2008 | 07:27 PM
Kisada's Avatar
tolga900,
while its true that visible wires look bad. Showing X owners a pillar cluster means nothing because we have airbags in those pillars and so will not likely be seeing A pillar gauge clusters.
Old May 26, 2008 | 11:54 PM
japbeercow's Avatar
Which wire and where did you tap for power?
Old May 27, 2008 | 11:50 AM
supersilverMR's Avatar
not sure if I would have drilled holes in my dash like that...nice job tho
Old May 27, 2008 | 12:45 PM
Thegame's Avatar
Power can be found in the cabin fuse panel. Personally speaking, I like to use add-a-circuits. There are about 5 empty IGN ON fuse slots and 3-4 Constant 12V fuse slots. They are all slots for things like heated seats, heated mirrors, power seats, sunroof, etc. All accessories we do not have.
*The Secondary fuse panel - The small strip to the right of the main cabin fuse panel has all of the constant 12V sources. The Primary fuse panel has all of the IGN ON 12 V sources.
Illumination can technically be taken from a 12V IGN ON slot, but it will stay lit while the car is on. The Tach and Speedo do anyhow, so why not? If you must have them tied into the lights, just tap anything that lights up when the lights are turned on. Hope this helps some guys because there's really nothing regarding the electrical install. I busted out my meter and crawled under the dash.
Old May 27, 2008 | 01:11 PM
ZE Power MX6's Avatar
I like the pod setup more
Old May 27, 2008 | 02:27 PM
meat_EVO's Avatar
i didnt drill any holes, nor do i plan on it.
Old May 27, 2008 | 06:57 PM
ovekcots's Avatar
where did you guys make your vaccum connection
Old May 28, 2008 | 06:46 PM
KDW's Avatar
KDW
Nice work, looks good
Old May 28, 2008 | 10:05 PM
Gary 805's Avatar
Man that looks sooooooo good man. Good thing you had help.
Old May 28, 2008 | 10:08 PM
BocaShula's Avatar
doesnt look bad bro
Old May 28, 2008 | 10:14 PM
h.funk's Avatar
Drill a little hole between the top of the dash and the dash board. AND make sure you screw your defis down to the dash. I had my defis stolen and my insurance woudnt cover them cause they were not bolted down. fyi
Old May 31, 2008 | 05:48 PM
meat_EVO's Avatar
^^ No
meat_EVO
23
Jun 12, 2011 09:17 PM
meat_EVO
Dec 7, 2009 09:10 AM
meat_EVO
Sep 1, 2008 10:22 AM
meat_EVO
May 26, 2008 03:52 PM
