LEDs installed (partially)
LEDs installed (Partially)
Looking for feedback. Keep in mind that removing the fogs is not a desired option. I am comfortable with the size of my LEDs. Currently neither side has mesh or the fake plastic mesh.
Should I do (2) Rows of LEDs?
Should I use aluminum instead of ABS plastic?
Add wire mesh?
For anyone interested, these are Oznium LEDs. Currently the one set is hooked up to parking lights.
Add wire mesh?
Should be two rows of LEDs spanning the entire bumper opening.
The only way this is going to look proper is if you remove the existing halogen fogs.
Otherwise it is a redundant element and looks out of place.
Make it look as close as possible to the Prototype X led fogs, those look OEM because of how well they sit in those openings.
I'm gonna try making an LED strip that will replace the Fogs and actually produce a usable amount of light using a bunch of Luxeon LEDs, (probably use the Luxeon strip which are 1W LEDs) If that doesn't work, then I'll move to the III or V or K2. I'm just having a tough time figuring out how to make a "diffuser/cover" without making the whole thing look "tacky/thrown together". Meh...maybe have to have some plastic lenses fabricated or something.
verkion
verkion
