Ben's AMS Sponsored EVO X
1) AMS has so much experience with race car set ups, a natural fit for what i want to do. They make sick parts that go fast!
2) The wing is functional so Im not really that concerned with the looks. I understand that some think it is ugly but i creates great downforce.
3) The Sabelt Harness was mounted using the top rear seat brace. My rear seat is removed so it runs parallel with the Recaro shoulder belt holes. Mounting on the top of the rear seat. The key is to keep the pressure parallel in case of an accident . If you use the lower mounts/lap belt location rather then the shoulder mounts, in an accident the pressure would create a downward motion pulling you down.
BEN
BEN
Ben, you should look into these type lighter carbon wings, it will give you the same downforce you needed with low drag on the track ! but if you are running in solo class (SM) that wing should work just fine.
http://de.youtube.com/watch?v=ErW3y8JP1Wk
same car?^^
same car?^^
same car?^^
same car?^^
https://www.evolutionm.net/forums/sh...d.php?t=359097
Looks good AMS and Ben....nice car!
