Smoked Lights
Old Aug 19, 2008 | 10:38 PM
ilive2win's Avatar
you have to bake the lights in the oven
Old Aug 19, 2008 | 10:55 PM
Enjoitk's Avatar
if anything requires baking my car parts in an oven.. ill pass lol
Old Aug 20, 2008 | 10:41 AM
ilive2win's Avatar
thats what i said at first too, but wanted my headlight blacked out from the inside, so i came up with enough courage to bake my headlights and they came out 100% better than stock imo. nothing melted, everything works great and loks better than before
Old Aug 20, 2008 | 12:45 PM
Ph3n1x's Avatar
I wonder when or if EvoDave will do anything for these.
Old Aug 20, 2008 | 02:42 PM
Pro-Spec's Avatar
do you have a better pictures for the work that you did, I am very interested. thanks
Old Aug 20, 2008 | 03:11 PM
DirectorSe7en's Avatar
I vote DIY for baking your lights in an oven.
Old Aug 20, 2008 | 07:07 PM
ilive2win's Avatar
Old Aug 22, 2008 | 11:06 AM
AWD_4life's Avatar
lots of vendors out there do it
Old Aug 22, 2008 | 01:53 PM
CKCougar60's Avatar
What vendors do it? Anyone near Washington?
Old Aug 23, 2008 | 08:47 AM
ricanevo's Avatar
Dremel?
Have anyone thought about using a Dremel to cut the lens off? I'm pretty good with it and once I get home from Iraq. I may try it.
Any thoughts on this?
Old Aug 23, 2008 | 06:08 PM
ilive2win's Avatar
u dont need to cut at all, once you heat the lense up the lense peels away from the rest of the light with no problems
Old Aug 23, 2008 | 09:36 PM
ricanevo's Avatar
what temp was the oven set for and for how long should it be in there for.
Old Aug 23, 2008 | 10:51 PM
ilive2win's Avatar
should be set at 250 degrees, check it in 10 min but i left mine in for 15. Bake at your own risk
Old Aug 23, 2008 | 11:06 PM
ricanevo's Avatar
yeah i tried this on my RSX in 02 and it was a mess. had to end up buying new head lights. how did you seperate the lens after baking?
Old Aug 23, 2008 | 11:26 PM
ilive2win's Avatar
I Used My Fingures, Its Kinda Hot But U Kinda Just Deal With It And Do It. How Long Did You Leave In The Lights From The Rsx? Cuz Mine Werent Even Close To Melting
