RR with Rexpeed, APR and Seibon New Carbon (Finally!)
archie, there is no connection between the nav and the larger antenna base. the nav's own satellite is inside your dashboard. it is attached by 2 screws suspending it on top of the nav. the larger antenna base is for the sirius satellite radio. i likewise dont care about the sirius satellite hence when i get my VG from the UK i will be replacing the antenna base to that of the base X models.
just finished helping a friend putting the VG on his X, it didn't have that gap problem, we cleaned the roof surface with alcohol swab, heat up the surface with a heat gun where the double sided tapes are, so it will stick better, weather is not that great here today, line up the front where antenna goes first and finished up the rear section where the rear window last, really simple. I think you might of placed the VG too close to the back window or the surface was not clean when you did it.
I cut the weather seal to size and added the 3m super thin double sided tape. Peel off and install, gap will be gone and it won’t look that bad actually.
