stock wheels with 20mm spacers and a drop
Old Apr 15, 2009 | 07:12 AM
  #31
Spunkysandoval's Avatar
Originally Posted by markg1018
Spunkysandoval, where did you get them? do they have a 10mm?? how does it bolt on? just install them in between the rims and the hubs?
I picked up these particular spacers from evasive motorsports
they have a variety of sizes from 10mm - 25mm. The installation is a breeze. Just install them between the wheel and the hub as you said. 30 minute installation for all four if you have help with taking the wheels off. It is as simple as removing and installing the wheel
Old Apr 15, 2009 | 01:35 PM
  #32
ZK's Avatar
ZK
I wouldn't go too big a spacer, with the stock wheels it will look really wierd if you look at it from the front and rear. You have the skinny stock wheels but pushed all the way out. 15mm is the limit for me.
Old Apr 17, 2009 | 01:32 AM
  #33
Dino Antonov's Avatar
looking good isaac
Old Apr 17, 2009 | 06:49 AM
  #34
Alexander's Avatar
Originally Posted by bigben
20mm is around 3/4in. I'd rather have a wheel that is 1in wider than have my wheels stick out 1in further. I looks good, but you can't really tell a difference of 3/4in on a pic.
which means you don't understand how offsets work. increasing your wheel width doesn't mean you're getting that extra width on the outside of the wheel.
if you have a wheel that is 1 inch wider without changing the offset, you only get half an inch on the outside and half an inch on the inside of an increase.
Old Apr 18, 2009 | 04:49 AM
  #35
Mitchubishievo's Avatar
Looks good, mitsu just loves leaving stock wheels tucked in stupid far.
On another note, you need to brush up on your OEM wheel specs and math according to the type seen in the first pic.
Stock is *18x8.5 +38 offset*
With the spacers, you've effectively made them *18x8.5 +18 offset*.
Old Apr 18, 2009 | 05:14 AM
  #36
Domolution's Avatar
Looks good dood........those are very useful.
Old Apr 18, 2009 | 09:32 AM
  #37
heavyD's Avatar
Ideally you should use wider wheels/tires with a lower offset rather than this type of setup. This setup will wear out the wheel bearings much faster. Also depending on your insurace company if your using spacers and a wheel falls off (this does happen) and you get into an accident your insurance company may be able to deny coverage.
Old Apr 28, 2009 | 06:31 PM
  #38
junk1337's Avatar
Originally Posted by Spunkysandoval
it's dropped on t1r coilovers
I had a set of wheels but I had to sell them due to money reasons, so I put the stocks back on but couldn't stand the idea of having the wheels being sunk in. The stock stance is so weak and as a personal perference I like to have a nice stance on my car. These wheel spacers are hubcentric which means that the spacer is centered perfectly on the hub and whe wheel is centered perfectly on the spacers hub. These have a hub bore diameter of 67.1mm and this is specific to the evo. It also has a thread pitch of 1.5. I would reccomend these spacers to anyone.
As for those who say spacers are "not worth it", if your refering to the price of the spacers, it should only be around 250.00 for all four spacers all around. That is the only thing I can guess worth is refering to. 250 is not a great deal of money to me for a better stance on a car that I drive every day and have to look at every day also.
some may like it and others may not. For me, it allows a stealth look and great stance. Stock wheels look great on this color and the handling feels great. Also, since these are hubcentric as I mentioned earlier, there is no vibrations at all
I love the look. Did you have to have the rear fenders rolled or is that not an issue? I'm thinking about 1.0 - 1.5 inch drop with 15mm spacers on stock wheels. Do you think I'll have any rubbing issues if I don't roll the rears?
Old Apr 29, 2009 | 12:07 AM
  #39
mangoes's Avatar
looks awesome! I think imma try a 25mm in the back though.
thank you so much for doing this!!! w00
Old Apr 29, 2009 | 08:40 AM
  #40
With that drop you shouldn't need any rolling at all.
These spacers are for sell now. Picking up a set of wheels today
Old Apr 29, 2009 | 10:45 AM
  #41
neveronlineten's Avatar
How much you want for them Isaac?
Old Apr 30, 2009 | 11:08 AM
  #42
huyissuperman's Avatar
Looks good Isaac!
Old May 2, 2009 | 01:42 PM
  #43
jirro22's Avatar
nice idea
MonsterParadise
Sep 30, 2011 10:26 PM
edwin
For Sale - Part Outs
125
May 10, 2011 04:32 AM
Gumby56
For Sale - Wheels / Tires
13
Aug 8, 2010 04:58 PM
gg4287
May 6, 2008 02:00 PM
bluej20
Apr 29, 2008 01:21 PM
