What is the best drying method?
Old Sep 19, 2009 | 03:30 PM
EsRt2evo's Avatar
waterblade for the majority of the water, then a shammy to get the water the blade missed. No swirls for me.
Old Sep 19, 2009 | 03:42 PM
DSMorBUST's Avatar
i put the nozzle on the hose to "mist"... spray it down.. then use an absorber.
sometimes i throw the leaf blower into the mix.. usually only in the fall/winter to cut down on time outside in the cold.. lol
Old Sep 19, 2009 | 03:57 PM
goforwand's Avatar
Leaf Blower FTW!
Gets the water out of the wheels, gas hatch, vents, seams, side mirrors, etc.
By the time I'm done, my white 100% cotton bath towel (per Zanio's advice) is only damp...
Old Sep 19, 2009 | 04:04 PM
cal1mr's Avatar
California waterblade. Works real nice, plus it's responsible since we're always in a drought. You know, as opposed to sheeting.
Old Sep 19, 2009 | 04:24 PM
aftershock141's Avatar
That is horrible for your paint. Do not recommend this to anyone. Windows, fine; paint, horrible.
Leaf blower is the best method followed by a nice waffle weave microfiber. I then touch up any spots I missed later with quick detail spray and microfiber.
Old Sep 19, 2009 | 07:57 PM
chapscalyx's Avatar
i use shamwow with no problem
Old Sep 19, 2009 | 08:09 PM
LancerEVA06's Avatar
I use the sheeting method with double filtered water, and then a shop vac (to get trim parts and in between panels/wing) and then a leaf blower. I refuse to dry with any kind of towel or chamios.
Old Sep 19, 2009 | 08:18 PM
slk1z's Avatar
I use a Master Blaster. Little bit better then a leaf blower. Its got 8hp peak, plus the air is heated and filtered. Awesome to say the least, takes 4-6mins to dry.
http://www.autogeek.net/mema.html
NOTE: If your car is not waxed, this will method will be a pain, but if it is waxed then you will wonder how you dried a car before
Old Sep 19, 2009 | 09:02 PM
accrane's Avatar
Originally Posted by EvoLou
California water blade.
Perfect way to swirl the crap out of your clear coat. Any little piece of dirt left on the paint will be picked up and dragged across the car, scratching it as it goes. Even if your very careful it will still happen.
I use the nozzle off sheeting method and a microfiber to dry...
Old Sep 19, 2009 | 09:26 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Go to Kragen/Pep Boys/whatever and get yourself an absorber.
Blot dry and don't drag across the surface.
Old Sep 20, 2009 | 06:39 AM
EvoLou's Avatar
Have you every used it? If you have and have got swirls then you don't know how to wash your car.
Old Sep 20, 2009 | 07:31 AM
Frankiago's Avatar
He's right though, you can even get small bits embedded into the water blade's rubber/plastic and drag it across like that. Unless you clay bar your car AND the water blade on a regular basis (which would be considered too often by detailing professionals anyways) there's no way you can stop the water blade from dragging impurities across your previously swirl-free paint.
Old Sep 20, 2009 | 12:25 PM
Lumpydonut's Avatar
dont use that damn water blade that thing is crap. I just use a good chamois and dont press down hard. absorbs like a diaper and dont leave nasty scratches
Old Sep 20, 2009 | 01:50 PM
ik78's Avatar
Old Sep 21, 2009 | 12:17 PM
Breakaway's Avatar
LOL just the bad noise the CA Water Blade made me not use it after a minute of trying. I'm happy with Chamois.
