Single muffler Evo X's
Old Nov 16, 2009 | 01:39 PM
  #106
AWDTerror's Avatar
Originally Posted by AJ PwR
Aluminum....... are you serious ? Aluminum will melt if the exhaust temp gets high...
Please stop posting.......
It is non-sense like this and mis-information that gets people all freaked out, you do realize that the 4b11T long block is die-cast aluminum with ductile iron cylinder sleeves.
Aluminum(raw) has a melting point of ~933.47 K/~660.32 °C/~1220.58 °F
A catback, even a test pipe and cat back will never even be close to the melting point.
Old Nov 16, 2009 | 02:00 PM
  #107
Frankiago's Avatar
Really? What's EGT pre and post-test pipe? I would think right at the flange where the test pipe meets cat back it'd be pretty damn close to 1200... I know there's a large transient across the turbo, but even at the down pipe it's pretty f'n hot.
Old Nov 16, 2009 | 02:08 PM
  #108
Lancerally_Mick's Avatar
Originally Posted by cheesefarmer
Here's my custom aluminum...weighs 7 lbs!
video plz !!!
Old Nov 16, 2009 | 03:07 PM
  #109
Frankiago's Avatar
Holy jeebus, all go no show at its finest
Old Nov 16, 2009 | 05:16 PM
  #110
AJ PwR's Avatar
No offence, I am not trying to mis-lead anyone here. Aluminum tubing and hangers are weak and they will have big chances to snap if the engine torques. You might be right in making exhaust in aluminum, it might work but how about durability ? I don't think the aluminum tube that cheesefarmer used is the same grade as the block. If he did then YES, I have to say sorry for freaking out others.
I know the block is made out of aluminum with cast iron sleeves (liner). Let's say "IF" the engine melts, it has to melt down the sleeve before it gets to the block and don't forget the block is water cooled.
Correct me if I am wrong
Old Nov 16, 2009 | 05:59 PM
  #111
Frankiago's Avatar
Most aluminum is very ductile in nature and a hot aluminum pipe, like an exhaust pipe at operating temperature, is even more ductile. Ductile materials NEVER "snap," as this brittle fracture is the result of a very hard and brittle material. Aluminum (again, especially hot aluminum) will break in a ductile failure.. the classic example is a frozen stick of bubble gum vs an 80 degree stick of bubble gum.
You're not giving aluminum nearly enough credit...
Oh and one more thing, the exhaust heats up rather quickly, so you'd have to start your cold car and then launch it within a few minutes in order to have enough engine torque to make it all the way to the cat back and "snap" the cold aluminum.
Old Nov 16, 2009 | 06:09 PM
  #112
aftershock141's Avatar
Remove.
Old Nov 16, 2009 | 06:34 PM
  #113
AJ PwR's Avatar
FYI, for ppl that are interested to build aluminum exhausts http://sccaforums.com/forums/thread/216833.aspx
Old Nov 17, 2009 | 04:21 AM
  #114
AWDTerror's Avatar
on my 2g DSM ive seen temp drops from pre-turbo(manifold) to the end of the downpipe almost 500F.
Old Nov 17, 2009 | 02:19 PM
  #115
Evol21's Avatar
Custom SS pipes with Burns muffler and Ti tip.
Old Nov 17, 2009 | 06:32 PM
  #116
cheesefarmer's Avatar
i used aluminum mainly for weight reduction and heat dissipation. my exhaust tip barely got hot in the summer when i was running the car hard. the stock exhaust tips actually felt hotter than the aluminum tip.
the exhaust is a little low under the axle, but i wanted it to be as straight as possible so it a compromise there. i've driven the car on gravel roads, and its been hit a couple of times, and it doesn't have any damage.
my friend who made the exhaust for me wants to re-do it, but with a custom muffler and titanium. he's currently doing a full header to catback titanium exhaust for an sti, and it looks phenomenal.
all i can say is the car sounds awesome @ WOT.
Old Jan 21, 2010 | 02:15 PM
  #117
wenbenten's Avatar
mORE PICS!!! STOP B@t%hINg
Old Jan 21, 2010 | 03:39 PM
  #118
.MM's Avatar
.MM
Old Jan 21, 2010 | 03:54 PM
  #119
morfhious3's Avatar
Originally Posted by pips
That's a Benen tow hook
just wondering if you have to do customizing on the benen tow hook to install it or just bolt on?can you show some pics too how the tow hook installed so that i could compare the underneath of a us and canadian evo.
Old Jan 21, 2010 | 04:34 PM
  #120
ARC_EVO's Avatar
i use to have a single exhaust kinda missing it lol
