carbon fiber vinyl
carbon fiber vinyl
this can be added to you dash trim or anything inside to give it that carbon look
http://www.youtube.com/watch?v=eWRICY21uqA
{thum bup}
good point.. i originally got it because I was going to put my gauges where the hazard switch is... But after taking apart the dash.. it isn't possible with the base radio.. didnt want to waste it.
There is a power wire that runs from the hazards to the controls of the radio.. In this pic you can see it.. its a flat thin white wire.. if you look above the word "Passenger" it runs right below the volume control. with that wire unplugged you cant turn the radio on..
Actually i've seen someone on here that has done it. he moved his hazards and put gauges there
i thnk it loos a lot better than oem. where did you get it? i have some pieces that i need done since i swiched them from an evo to my base lancer that didnt have those accents.
josh
josh
