Official: Volk/Rays/Gram Lights wheels thread (Evo X only)
Is anyone running Volks with 18x10.5 with an offset of 24? with 273/35
I'm not concerned about rear fenders since I'm rolled already. I'm more concerned about clearance to the suspension, frame, metal or anything mechanical (not worried about rubbing fender liner).
Thanks
Thanks
bump - anyone running ce28SL in 18x9.5 with +35 offset?
So the 18x9.5 CE28N +34 definitely fits the X calipers?
What is the middle wheel size?
The difference is that 18x9.5 +34 ce28n spokes are more flat and not as concave. Flat face = more caliper cleareance.
Pretend you're looking at a cross section of a rim. A flat face rim would look like a " T " where a concave face looks more like a " Y ". You can see how the wheel profile will effect brake caliper cleareance.
19x9.5 +22 ce28n spokes arent as concave as the 18x9.5 +22 which is why you guys running the 19's will have more cleareance than the picture posted above.
18x9.5 +22 CE28N OE brembo clearance
18x9.5 +22 CE28N w/ 5mm spacer w/ Stoptech Trophy 6 piston clearance (Trophy comes out 3mm further than OE brembos)
18x10.5 +18 CE28N w/ Stoptech Trophy 6 piston clearance (Trophy comes out 3mm further than OE brembos)
18x10.5 + 18 RE30 w/ Stoptech Trophy 6 piston clearance (Trophy comes out 3mm further than OE brembos)
wheel line up
wheel line up
