Fonzo Performance 3 Gauge Pod
Old Dec 6, 2010 | 03:21 PM
WILFAST's Avatar
Patent Pending/Trademark/Copyright 2010 Fonzo Performance
Biters beware!
-No Holes in your Dash
-No Blocking your view
-No Blocking your Speedo/Tach
-No Blocking your Airbags
-No Changing your stereo
http://s815.photobucket.com/home/wilfast/index
from building r/c cars to custom full size cars...
Old Dec 6, 2010 | 03:23 PM
migs647's Avatar
What happened to the hazard switch? Why is it so far to the right?
Looks good otherwise. Better photo would be appreciated
Old Dec 6, 2010 | 03:49 PM
WILFAST's Avatar
Hazard Switch!/Version 2
When I designed this gauge pod I sat in the driving seat and wanted to place the gauges so that not only did they not block the view outside the vehicle but inside also! they are far right to prevent the visual block of a/c gauges.
I also have a version 2 that allows for a closer gauge pod location and flat switch panel!
As far as the hazard switch goes, I wanted to create a clean look without destroying any stock parts. the entire hazard switch panel was moved below the a/c panel in the location where the stock rca audio jacks were. So if at a later date you wish to remove the gauge pod and put all the original parts back you can!
clear pictures can be seen
Old Dec 6, 2010 | 04:23 PM
morfhious3's Avatar
rather have the version 2.doing version1 and moving the hazard is another work instead just doing the gauges.
Old Dec 6, 2010 | 04:26 PM
Evo10HKS's Avatar
looks weird and out of place to me.
Old Dec 6, 2010 | 04:36 PM
Bob Evolved's Avatar
looks like you took a 3 gauge A pillar pod and chopped it up then slapped it onto our dash trim and wrapped 3m over it
Old Dec 6, 2010 | 04:44 PM
MACKLIN's Avatar
great idea but not really feeling it.
Old Dec 6, 2010 | 05:08 PM
pflores210's Avatar
Looks stockish nice
Old Dec 6, 2010 | 05:13 PM
racingguy13's Avatar
I like the concept, but not sure I like the execution. If you did the first version, relocating the hazard switch setup down lower, and then set up the gauges lined up with the HVAC controls or centered with nav/radio, tilted just slightly towards the driver, I think that would be much better and look more OEM. I've been wanting to do this but haven't had the time or ambition yet, it's on the winter project list. But if I could find a decent price one already setup that way, I could be interested
Old Dec 6, 2010 | 06:19 PM
WILFAST's Avatar
what would you be looking for in a gauge pod?
Old Dec 6, 2010 | 06:21 PM
WILFAST's Avatar
Sounds Good!
I might do a rough mold and see how it looks! Thanks for the Constructive Criticism.
Old Dec 6, 2010 | 06:23 PM
WILFAST's Avatar
What dont you like?
What dont you like?
Old Dec 6, 2010 | 06:41 PM
chaotichoax's Avatar
please keep in mind that you are not a vendor so any attempts at solicitation will result in a warning and deleting of the thread
Old Dec 6, 2010 | 06:46 PM
WILFAST's Avatar
This is how I respond!
Thank you for your opinion!
But the gauge pod was actually made from scratch with fiberglass and bondo if you would like to see build pics I can PM them to you if you are interested! It was a lot of molding, sanding, and fitment! To add to that, the one that is covered in the 3m is not the one in my car it was one of many different ones Ive built!
If you have time tell me what you think of my car!
Google:
Fonzo Performance
Wraptivo Evo X
Flat White EVO X
you should be able to see a few pics/videos!
do you have any links to your car, I would love to see what you've done with it?
Old Dec 6, 2010 | 07:17 PM
Google:
Fonzo Performance
Wraptivo Evo X
Flat White EVO X
Thank you for offering me the build pics but I know how much work goes into making a custom gauge pod, heres the gauge pod I made. Its kinda like yours, but its made from carbon fiber.
p.s. I really like your car
