So i just bought my brand new OB GSR and the dealership had to go get the car from Maryland which requires the front license plate. Here in NC we don't need the front license plate,
But if i take off the bracket then theres holes drilled in the front bumper i need to cover up. Should i have them fix it or can i buy things that pop it or what?
Thanks
Thanks
When I took the bracket off, I went to a local Ace hardware or whatever is in your area and just went to the aisle with all the screws, plugs, corks, etc. I found little black plugs (that's the best description I can give- they look like big, black screws I guess) that fit over the hole and used some apoxy to secure them down. It doesn't look that bad and isn't too noticeable. It shouldn't cost you more than $5.00. Good luck!
another option (if u want to run the front plate) is buy the beatrush license plate bracket. its not big like the OEM one and looks great to me! i went that option after getting harrassed by cops while not running the front plate.
i can post a picture if you want. good luck!
+1 for a picture Originally Posted by jdmEviL8
another option (if u want to run the front plate) is buy the beatrush license plate bracket. its not big like the OEM one and looks great to me! i went that option after getting harrassed by cops while not running the front plate. i can post a picture if you want. good luck!
Ugh... I don't see how that solves anything?
There has been a few pictures of people using color-matched plugs. Can barely tell.
