Finally put gauges in
Old May 12, 2011 | 07:18 AM
NateDaJew's Avatar
I practiced and plotted but I'm finally happy with the install. I tried not to use any plastic weld. I made a C/F plate and used angled spacers for the gauges. Thanks for all the info I found on this site.
Attached Thumbnails Finally put gauges in-2011-05-08_01-10-10_88.jpg   Finally put gauges in-dash-2.jpg
Old May 12, 2011 | 07:46 AM
EVOXMAINE's Avatar
Looks good man!!! I have had the trunk on for a while now! Lookin good Thanks for the deal! Loving the wingless look without the holes!
Old May 12, 2011 | 07:50 AM
NateDaJew's Avatar
Good to hear everything worked out. I'm thinking about a CBD hood now.
Old May 12, 2011 | 08:34 AM
XstormtrooperX's Avatar
Nice job. Is that wrapped in actual CF?
Also where did you relocate the HAZ button?
Old May 12, 2011 | 08:37 AM
NateDaJew's Avatar
It's actually CF and HAZ is going in the lower pocket tonight.
Old May 12, 2011 | 09:01 AM
Fantastic job. I'm thinking of doing the same. Did you wrap the entire trim piece?
Also, I was thinking of relocating the HAZ button and was thinking about using a traditional round button instead, and wiring it in. Will I have problems if the ugly passenger airbag/seatbelt lights are not used?
Old May 12, 2011 | 09:06 AM
Pirana's Avatar
need to mass produce!
Old May 12, 2011 | 09:18 AM
NateDaJew's Avatar
No wraps, all real CF. You have to use the entire HAZ pod or you will get a light on the dash.
Old May 12, 2011 | 09:38 AM
Zombie Killer's Avatar
That looks FANTASTIC. I was just thinking the other day that the trim needed to be actual CF instead of that plastic trim. Any permanent alterations to the dash?
Old May 12, 2011 | 09:54 AM
NateDaJew's Avatar
I cut out the piece that hold the HAZ switch.
CatalystIX
Feb 10, 2008 02:53 PM
webguy330i
Dec 22, 2006 12:52 AM
wiretap
Jun 11, 2006 12:30 AM
r6bruin
Mar 27, 2003 03:21 PM
ILP Performance
Lancer Vendor Classifieds
23
Jan 22, 2003 11:49 PM
