Do-Luck and Aeromotions wing with Aerofloor
Old Oct 7, 2011 | 01:47 AM
  #31
MDH-005's Avatar
LOL I have no idea what that is!
Old Oct 7, 2011 | 01:51 AM
  #32
MDH-005's Avatar
Street version:
Time Attack Version:
Old Oct 7, 2011 | 05:03 AM
  #33
Max1000k's Avatar
This is looking very nice!
Old Oct 7, 2011 | 07:19 AM
  #34
MDH-005's Avatar
Originally Posted by f1av8trfan
Innovative design and great work under the car. I can't help but wonder about the upper airflow. Have you done airflow tests on the rear spoilers? With a vortex generator, duckbill and the wing I'm not sure where the air will be going. Does it generate enough positive downforce to offset the drag created by the 3 elements?
Vortex generators are designed to reduce drag, as the prevent the creation of a large single vortex, by creating a series of smaller ones. Smaller vortex' have a lower net effect on drag.
The same concept applies to the diffuser. The angle of inclination is designed to ensure that the air flow does not detach from the underside of the car. This reduces drag. Also the diffuser is split into sections to ensure that multiple (small) vortex' are generated.
The upper deck of the diffuser is for cooling and aesthetics only.
The trunk lip is cosmetic.
Old Oct 7, 2011 | 07:21 AM
  #35
MDH-005's Avatar
Originally Posted by h4ckluserr
Let's play "name the mystery hole in the rear passenger door?"
my best guess is that it's the reflection of some type of speaker?
Cold air intake on a Nissan Patrol maybe
Old Oct 7, 2011 | 09:00 AM
  #36
SilverEvoX's Avatar
I wish someone would just make a full replacement carbon fiber one already and not just an add on lower like the JUN/Varis one. I'd love to have one just a little more aggressive than your street one, mainly just a bit wider and slightly under the rear spats
Old Oct 17, 2011 | 08:58 AM
  #37
chkmgnt59's Avatar
I LOVE the undertray and the street diffuser. I couldn't get away with the race one as I do have to drive the car around town sometimes. But I'm in to see if these make production.
Old Oct 17, 2011 | 01:07 PM
  #38
MDH-005's Avatar
Street Testing
Old Oct 17, 2011 | 01:14 PM
  #39
chkmgnt59's Avatar
What price are you thinking the whole setup will run? Splitter w/ full undertray and street diffuser?
Old Oct 17, 2011 | 01:15 PM
  #40
MDH-005's Avatar
The car does a flyby at 50 sec!
The SLS and 458 turn up at 1:20
http://www.youtube.com/watch?v=xGQFz...layer_embedded
Old Oct 20, 2011 | 08:58 AM
  #41
Chebosto's Avatar
wow.. check out that rooster tail behind you that your underbody is sucking up and spitting out.
pretty cool.
who made the flat bottom?
Old Oct 20, 2011 | 07:39 PM
  #42
f1av8trfan's Avatar
Agreed. Again, Nice work! However the Mitsubishi pdf on the design aerodynamics for the Evo X found the roof vortex generator not needed. I understand the trunk lip is cosmetic but it will still be directing airflow. Just curious.
Old Oct 20, 2011 | 09:41 PM
  #43
grant_ca1's Avatar
Gangsta!
Old Oct 21, 2011 | 12:17 AM
  #44
h4ckluserr's Avatar
Do you have this PDF? I seem to recall this being different for the MR. by creating the smoother air they were able to effectively use a trunk lip for generation of additional downforce with the use of a Vortex generator?
Old Oct 21, 2011 | 06:23 PM
  #45
Chebosto's Avatar
the reason being, on the 8/9 the slope of the rear window was significant enough that air flow was separating before reaching the bottom of the window. Since the 8/9 had the stationary box wing in place, by adding the vortex generators on the roof, it prolonged flow attachment to the surface, hence allowing faster air flow underneath the box wing, which allowed the underwing surface to work better to create the negative lift (downforce)
the reason why the X doesn't really the VGs is because the rear window's slow is more gradual, and the shape of the X roof allows for adequate flow attachment underneath the X's wing shape. the VGs on the X.. well.. most likely more cosmetic than anything.. it does complement his car
