Front License Plate - No Drill
Old Nov 10, 2012 | 01:42 AM
  #61
SD_Lurker's Avatar
Originally Posted by f-dub
Not sure if serious, but let me save you the few clicks anyone with an 8th grade reading comprehension would have been able to figure out by now.
No I get it but the guy wasn't posting that parts list. Did you notice someone said they're tired of waiting and they went and found it themselves?
Old Nov 28, 2013 | 04:34 PM
  #62
dkorr's Avatar
attepted this today... make some modifications
Parts list update:[/U]
Hillman T-Nut (from Loews) 3/8-16 X 7/16
Everbilt 5/8 Grommet (from Home Depot)
As you can see the bolts sits just below the front surface of the plate holder. I used a 4 1/2" cutter to cut the bolts and the T-Nut. That way you can eliminate the need for stacking all the nylon washers. So for each attachment point I had: bolt/washer/frame bracket/washer/grommet/T-Nut/3M tape (double layered).
Old Nov 29, 2013 | 11:16 PM
  #63
08wwevoXshane's Avatar
Genius idea!
Old Apr 6, 2015 | 10:44 AM
  #64
nala's Avatar
Just wanted to check in with folks who have used this approach to mounting the front plate - how has it held up after years of use? Has the tape held up?
Fishstix
Oct 20, 2011 06:31 PM
big block ix
Dec 19, 2010 08:46 AM
big block ix
Nov 18, 2010 07:04 PM
big block ix
May 11, 2010 03:53 AM
MyEvoDream
Nov 12, 2009 09:15 PM
