Varis Widebody Kit
You should be able to run a ton wider than a 305 with that kit. I'm pretty sure a 325 or 335 would fit in that fender well with a 18x11 easily. Very few would need that much rubber because it's a bunch of extra weight unless you need the grip on a crazy hp setup.
Varis Booth at TAS - http://www.youtube.com/watch?feature...&v=mvQecPBXcnM
The front end looks ****ing money. Then you walk around to the side of the car where it looks like they did that section on a bad acid trip, then did the rear fenders while hung over and then you walk around to the rear, and it looks like they just ran out of time.
The worst part is the front fender where it meets the side skirt, it doesn't flow at all.
