Cleanest Boost/AFR/Voltage gauge EVARRRR!!
Old May 16, 2012 | 03:29 PM
  #31
vivimatsuk's Avatar
this is awesome! def going on my mod list! very clean
Old May 17, 2012 | 12:20 AM
  #32
Freebs's Avatar
I love this option! This will be my next purchase for sure... My only question is will it work for tuning/logging with the COBB AP? And if so how would one go about doing so?
Old May 19, 2012 | 08:15 AM
  #33
lossol's Avatar
Considering the majority of Evo X owners use the AEM, that would be a great idea. Is there a difference between the AEM serial feed and the PLX's? I'd be in if you could make it happen!
Which AEM model number Are your guys using? I will be expanding VBG1 AFR input capability to be compatible with AEM.
VBG1 does not use the OBD-II port, so this will not interfere with the COBB AP.
Old May 19, 2012 | 01:30 PM
  #34
gsrdc2's Avatar
aem uego gauge part #30-4100
Old May 19, 2012 | 09:51 PM
  #35
NateDaJew's Avatar
Sweet so I could just hook my current aem gauge to it.
Old May 20, 2012 | 01:02 AM
  #36
fshizl's Avatar
I cant wait for these to be released. I want to buy one so bad...
Old May 23, 2012 | 05:17 AM
  #37
lossol's Avatar
To clarify, VBG1 supports the aem uego gauge part #30-4100 Analog output. The configuration setting for aux input should be set to LC-1 as this gauge has the same lookup table for voltage vs AFR. (the serial connection is not yet supported for AEM)
VBG1 now shipping for the EVOX community, get your VBG1 at www.gtboostgauge.com
Old May 24, 2012 | 09:52 PM
  #38
Hakmeister's Avatar
Not a huge fan, wish it was a little bit bigger
Old May 25, 2012 | 12:04 PM
  #39
Bob_tm's Avatar
We need SST oil temp with relay to SST oil cooler (relay is on when sst_temp more than 75C )
Old Jun 6, 2012 | 06:41 PM
  #40
arximus's Avatar
very clean would love to hook this up to my AFR
Old Jun 7, 2012 | 02:52 PM
  #41
Devgamer's Avatar
Installed mine today. I'm pretty happy with it. I would like to figure out a way to get it more flush with the front face of the vent though. Has anyone tried any modifications of how it sits? Seems too angled back at least from my sitting position.
Old Jun 20, 2012 | 06:24 PM
  #42
HudsonFalcon's Avatar
For the VBG1 to read AFR I would still need the AEM gauge itself since it acts as the controller correct? Or is there a way I can wire it without using the actual gauge?
Old Jun 21, 2012 | 03:50 AM
  #43
lossol's Avatar
VBG1 is compatible with the following afr monitoring systems:
 Innovate Motorsports LC-1,
 AEM 30-4100 UEGO
 Zeitronix Zt-2 or Zt-3
 PLX SM-AFR
The PLX, LC-1 and Zeitronix offer stand alone operation. Since the control electronics is built into the UEGO 30-4100 - stand alone operation is not an option.
I hope to upgrade the firmware soon to the VBG1 to allow further compatibility with UEGO gauges and afr monitoring systems.
Currently the AEM 30-4100 UEGO has the same analog output AFR/voltage ratios as the LC-1. That is the reason only this UEGO AFR system is compatible thus far.
Old Jun 21, 2012 | 06:56 AM
  #44
EricLee7481's Avatar
Any plans for EVO 8/9 application?
Old Jun 21, 2012 | 09:43 AM
  #45
NY Black momba's Avatar
very stealthy look
