Lotsa Tomei Ti Expreme Goodies!
You will not be disappointed once you see this in person
If anyone is looking for more info you can Click Here!!
Let us know if you have any other questions on this awesome exhaust!
-Dallin
-Dallin
get the cel fix from the ams website, its going to come with a set of inserts, DO NOT INSTALL ANY, just install the o2 sensor onto the fiting with the gasket. thats what i did, and also did to my cousins evo 10, and no check engine light everrr..
Let us know if you have any other questions on these parts
Have a great weekend everyone
-Dallin
That I am aware of I don't believe you would have any leakage with the test pipe mounted up to the AMS Downpipe. They should both use 3" 2 bolt flanges and the test pipe is just replacing your OEM Cat.
Let me know if you have any other questions or concerns on this.
Also for those wondering here are all the parts which we used for this install:
Tomei Expreme Ti Titanium Catback Exhaust Mitsubishi EVO X 2008-2013
Tomei Expreme Ti Titanium Test Pipe Mitsubishi EVO X 2008-2013
Tomei Expreme Downpipe Big Mouth Mitsubishi EVO X 2008-2013
Thanks,
-Dallin
We are running the Tomei Expreme Big Mouth Downpipe.
Thanks,
-Dallin
Thanks,
-Dallin
You will over time aquire a leak using the AMS downpipe and Tomei TP. I had the Tomei TP and exhaust as well as the AMS downpipe. I noticed the Tomei tapered so I matched them up and its not a good match at all. The Tomei flange is so mcuh smaller than AMS or ETS flanges. There is in all honesty a few millimeters where the flanges will actually seal toether. I hate the Tomei exhaust for tapering it like that but if you're running the stock cat it fits good.
Like the thicker Remflex 3" 2 bolt gaskets we carry.
Maybe I will see what I can find out with the flange shape/ size of the two.
Thank you for the heads up I will do a bit more research into this.
-Dallin
I have them both right here in my house. The AMS flange is much bigger in overall diameter. They're obviosuly both 2 bolt so the bolt holes match up fine but its because of Tomei's taper that they used a much smaller flange. I can take pictures if anyone would like.
I believe they will still work fine just be aware that they need to be aligned perfectly for the provided gasket to seal properly or go with a thicker gasket that will help prevent any leaks between the two flanges.
Thank you SD_Lurker
-Dallin
