Lotsa Tomei Ti Expreme Goodies!
If the AMS's flange is actually bigger than the Tomei, they yes I could see this causing an issue and were you would want to run a thicker gasket to prevent leaks that the Tomei Metal gasket could have in this situation.
Like the thicker Remflex 3" 2 bolt gaskets we carry.
Maybe I will see what I can find out with the flange shape/ size of the two.
Thank you for the heads up I will do a bit more research into this.
-Dallin
-Dallin
Thanks
How would you compare the Tomei two piece slipfit design to the AMS one pieces cast stainless steel? I'm not refering to weight... I want to know the difference in durability, resistance, quality, performance, fitment and overall item.
I own the AMS downpipe and I'm familiar with its characteristics, but how would the two compare? I know Rick from RallySport Direct, made a video of "What's in the box" and from the sound of it, he loved the AMS DP. I just want your imput on the two.
*I know the AMS DP is a little more expensive ($60 more to be exact)*
PM Sent
I have held both in my hand and looked at the quality of both up close.
Comparison wise these two downpipes are similar, but different. In performance wise they have a similar designs both with big mount opening for increased air flow form the turbo. Quality is top notch on both of these and both have been extensively tested and deigned.
The Tomei Big Mouth opening is a cast piece that can withstand a lot of heat and is built out of the same 304 stainless Steel as the AMS downpipe. Durability and heat they will perform identically.
Fitment is great on both of these pieces and no issues that I have personally encountered with ether one.
I do recommend ether one of these to anyone as they are both top quality and excellent parts.
Let me know if you have any other questions or concerns.
Kind Regards,
Kind Regards,
Yes this car gets driven daily on the street
We cleaned it up really well. It's amazing what a little TLC and elbow grease can do when cleaning PM Sent
-Dallin
very nice!! A couple number short from the 10 but I have tomei cam and downpipe.. love the quality and performance of their products.. would like to dress the bay with their heat shield spark plug cover and oil cap
The older Evolutions will always hold a soft spot in me
If you have any questions on any of the other Tomei Evo Products we carry and stock their full line
-Dallin
