Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
NEW Release Cobb EVO X Sway Bars
Old Oct 15, 2008, 01:51 PM
Silver Sponsor
RallySport Direct's Avatar
Cobb Just released their new Swaybars for the X Here is the info on them
COBB Tuning announces immediate availability of the 2008 Mitsubishi EVO X anti-swaybar kit. This kit dramatically decreases bodyroll and improves handling, encouraging the driver to attack the corners while inspiring confidence at the limit!
The COBB EVO X Anti-Swaybar Kit has multiple settings both front and rear, giving additional adjustment so handling canbe tuned to driver preference. Rear bar stiffness can be increased up to 176% over stock, improving balance and reducing
inherent understeer without impacting ride quality. This kit is a direct replacement for the factory equipment. The lightweight tubular bars are CNC bent for a precise fit which makes installation simple. The kit also includes polyurethane bushings for quick transient response and bushing mounts with integrated grease fittings for easy maintenance.
EVO X Anti-Swaybar Kit Features:
• Two position front bar: 108% and 125% rate increase over stock
• Three position rear bar: 106%, 132% and 176% rate increase over stock
• Tubular bars for weight reduction
• CNC bent for precise fit
• Polyurethane bushings for immediate response
• Bushing mounts with grease fittings for easy maintenance
• Integrated bar locaters to prevent “bar walk”
• Tough powder coat exterior for weathering the elements
I had the chance to drive around the track in my EVO IX track car at the same time they were testing these, and I can say I was pretty impressed with how fast that car was and how flat it looked for a car just on springs and sway bars. Alot of testing went into these from Cobb and I think a really great product came out.
I would def recommend them to anyone wanting to take some of the body roll out of the car and improve handling.
Old Oct 15, 2008, 03:25 PM
GTWORX.com's Avatar
Sweet!
Anti-walking tabs, tubular construction, mounts with grease fittings. These sound great.
- Andrew
Old Oct 15, 2008, 03:46 PM
JoeyM3's Avatar
how much will they run? do you have to buy both or can you just buy 1?
Old Oct 16, 2008, 01:14 AM
fastkevin's Avatar
How come they don't mention the diameter of 'em?
Old Oct 16, 2008, 09:22 AM
Silver Sponsor
You can buy them seperate or together.
MSRP is $165 per bar. We have a thread in the for sale section if you are interested.
These are hollow sway bars so the diameter would not be a direct correlation to a solid type sway bar. I will be happy to take a mic to them and let you know what the sizing is.
Since I know the % increase as soon as I find out the stock sway bar diameter I could tell you what they would be equivalent to in a solid sway bar.
I am looking into this info and will post when I have my results.
Old Oct 16, 2008, 09:43 AM
Silver Sponsor
Cobb just got me the stock sway bar sizing it is 25mm front and 23mm rear
So using a conversion chart the front would be closest to a 30mm front solid bar
and the rear would be closest to a 27.5mm Rear solid Bar(all converted from the lowest % rate increase)
This is using a conversion chart from whiteline and a disclaimer is at the bottom of it:
IMPORTANT : This chart is purely for rough comparison
purposes and is only designed to serve as a guide. It can
not be used when comparing different bar shapes, designs
or material specifications.
So please keep that in mind
Old Oct 16, 2008, 10:07 AM
Miles08WWSSSX's Avatar
The bars look nice, totally off topic do you know when the access port for the x will be available
Old Oct 16, 2008, 01:07 PM
Silver Sponsor
I know they are working furiously on it. Buzz around is we are hoping pretty soon (before christmas) but nothing is for sure yet.
But you didn't hear that from us
Old Oct 17, 2008, 12:53 PM
HaleRzr's Avatar
How well would these compliment Works springs? Looks like works only has a rear sway bar available for the X, no front.
Old Oct 17, 2008, 01:13 PM
Silver Sponsor
I have not had the opportunity to ride in a EVO X with work springs. I know Works does a great job with their products so I am sure they are top notch.
But with ANY spring these will help reduce the body roll from side to side on hard cornering and with the adjustments allowing you to play with the balance of oversteer and understeer makes for a very versatile setup.
P.S But I have ridden in a car with Cobb springs and thought they were incredible.
Old Oct 18, 2008, 12:33 PM
Gators2001's Avatar
Dont understand how u did ur conversion, so what would it be for the highest rear setting?
Old Oct 20, 2008, 09:02 AM
Silver Sponsor
It would be equivalent to approx 29.5-30mm rear bar when on the stiffest setting.
Old Oct 21, 2008, 10:27 AM
Silver Sponsor
If anyone is wanting the see the conversion chart I used to get this information it is located here
http://whiteline.com.au/docs/bulletins/010barup.pdf
There is also a good write up on hollow vs solid type sway bars if anyone is interested.
http://whiteline.com.au/docs/bulleti...%20Swaybar.pdf
Old Nov 2, 2008, 06:30 AM
Cool thanks dude, just have to be patient with them like with any new part.
Old Nov 3, 2008, 08:08 AM
Silver Sponsor
np I am excited to see how well the AP works on the EVO X being local it will be super sweet for you
Quick Reply: NEW Release Cobb EVO X Sway Bars
