Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Brake Retainer Pins Question
Old Mar 2, 2016, 07:08 AM
jayt27's Avatar
Hi all- I just changed my front brake pads this weekend and since I didn't have a center punch tool, I just ended up using a small screwdriver/hammer to remove the pins. By doing so, it shaved off some of the tip of the retainer pins when I hit it.
The tips of the pins are still pushed far enough that it "slightly" extends past the surface of the calipers. Should I be worried of it slipping out? I checked for the price of the pins and its about $14 each, but I don't want to waste money if I am just being paranoid. Thanks!
Old Mar 2, 2016, 07:55 AM
meckert's Avatar
As long as you got them in the rt way--you should be fine. The tension from the brake clips will help hold them in. A word of wisdom, that punch would have been a couple of bucks, now you still need a punch and $56.00 to correct the issues of not using a punch.
Old Mar 2, 2016, 09:02 AM
hoobastnk90's Avatar
Yea you should be fine just check it after a couple hundred miles and if it still looks good then I wouldn't worry about it.
Old Mar 2, 2016, 09:50 AM
evostanman's Avatar
Should be good
CaptainAsia
May 18, 2014 04:46 PM
blackenedwings
Aug 22, 2011 08:18 AM
toysgetsmoked
Oct 17, 2010 11:01 AM
Knightr
44
Aug 14, 2009 06:44 AM
DaWorstPlaya
Oct 21, 2008 09:47 AM
Quick Reply: Brake Retainer Pins Question
