What else do i need to make my X MR Handle BETTER?
He said they were installed per instructions. Not sure.
Yeah, the instructions give you a starting point for damper adjustments, that's what I mean. He even said he left them alone because he had no clue what adjusting each one would really do.
What bushings are you going with? I like the Ralliart Group N bushings, they are OEM quality and a harder rubber than stock (no squeaking).
rhdJapan can supply them, even the ones not listed on their site if you provide them the part numbers.
https://www.rhdjapan.com/search/mode...dling_bushings
http://www.lancerregister.com/showthread.php?t=394898
http://www.rosssport.com/Catalogue/E...USHES/RALLIART
poly bushings also have the advantage of a lot less friction for rotating, so your springs and dampers are doing the intended job and not bushing twist. and SuperPro have a lifetime warranty, even with race use, if you're worried about them breaking down.
I had Beatrush diff bushing inserts on my Evo X and it was great, I'd recommend that over replacing the full bushing. it does the same thing and saves you a bunch of money on install cost or makes your life a lot easier if you're installing it yourself
https://www.maperformance.com/produc...cer-evo-8-9-10
MAP also carries SuperPro bushings, give them a call or pm for best pricing instead of just ordering off the site.
To help the front end from understeer at the track I installed a rear eibach swaybar on the tightest setting with whiteline endlinks. It was quite noticeable on the street and made the car feel better in quick turns. I don't mean driving like a jack wagon on the street, but even just some fast on ramp type cornering it was a massive improvement compared to the stock body roll. Since it doesn't affect bump response the ability to drive on rough roads isn't impacted much. I recommend this upgrade for both the street and the track.
~Jaraxle
~Jaraxle
^^ yes thank you i should of ordered a sway bar too.
Doing it now but im getting whiteline. :P
What about the FRONT sway bar?
Whats the widest wheel & tire size you guys recommend? I would like to go wider then my 9.5" wheels that i have now.
Im thinking of a hybrid install of a Victory front fenders and a varis rear fenders.
I'm a big fan of SuperPro, have their stuff in 2 of my cars. No squeaks going on the 3rd year in one of them now. personally I'd go with SuperPro's poly bushing for that big front control arm bushing, but you can do Whiteline's spherical bushing if you're really hardcore... but you'll prolly get some noise with that
I bought BLACK COLOR (i forgot from who) rear diff bushings a while back but never installed them.
Im gonna install them with this setup.
