Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
FE with the GSR rims
Old Nov 10, 2017, 08:40 AM
cloom2000's Avatar
Hi few days ago i install GSR's rims with the winter tires ( Nokian Hakkapeliitta R2) on my FE, tires are the oem sizes. When im on full turn the tires are rubbing against the wheel well.
Where is the problem ??
Old Nov 10, 2017, 09:10 AM
e_kobz's Avatar
The GSR and FE Enkei's are the exact same size offset. OEM tires are 245/40/18. What size are the winter tires you installed?
Old Nov 10, 2017, 09:16 AM
e_kobz's Avatar
Did a quick google search. A standard summer tire in 245/40/18 is on avg 25.7" tall. The winter tire you have in the same 245/40/18 size is 26" tall. So the extra .3" inches of tire height could cause the rubbing at full lock.
Old Nov 10, 2017, 09:18 AM
cloom2000's Avatar
Same 245/40/18
Old Nov 10, 2017, 09:21 AM
cloom2000's Avatar
so the .3 inch will make the problem ?
Old Nov 10, 2017, 09:24 AM
e_kobz's Avatar
It's a possibility. It wouldn't worry about it too much. How often are you really turning lock to lock
Old Nov 10, 2017, 09:26 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Yes, it will. I have found that pretty much EVERY 245/40r18 other than the stock advans will rub the wheel well liners at full lock. My wifes car had 245/40r18 Michelin Super Sports on the stock wheels, and they rubbed at full lock...lol. The stock Advans are oddly small.
Old Nov 10, 2017, 01:47 PM
six40's Avatar
Yeah my stock size SC2's rub lock to lock too. Stock size Continentals I temporarily have now on RPF1's also rub the same way.
Old Nov 10, 2017, 02:57 PM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Originally Posted by e_kobz
I wouldn't worry about it too much. How often are you really turning lock to lock
Bruh, opposite lock snow drifts.... duh
Old Nov 10, 2017, 04:15 PM
e_kobz's Avatar
Im in Arizona (north northern), I know nothing about that
Old Nov 10, 2017, 04:33 PM
RazorLab's Avatar
Right, but the OP is talking about Nokian tires, so he is obviously about to drive the car in white fluffy stuff.
Old Nov 27, 2017, 11:09 AM
yubiyangctt's Avatar
The FE's enkei is the same as GSR's, just different finish on them. Cheers
Old Dec 10, 2017, 06:18 PM
Hiboost's Avatar
In general the snow tires will have a slightly larger diameter when brand now as well due to the typical deep tread depth they would have. Are they rubbing the inner wheel plastics or the vented section in front of the tires that tends to bend around a bit. If it's the later you can use zip ties to pull the plastic vented fender pieces away from the tires a little so they avoid contact when the tires are turned.
Qutenoypi
Jan 2, 2011 06:15 PM
sofly1990
Oct 24, 2009 05:45 AM
ssevo8
For Sale - Wheels / Tires
28
Oct 9, 2009 10:20 PM
Quick Reply: FE with the GSR rims
