Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
New Rotors & Pads Grinding
Old Nov 28, 2017, 04:03 PM
Gr1m's Avatar
I'm new to the Evo community and Brembo brakes. I installed some Stoptech slotted rotors and Hawk HPS pads in the rear. I'm hearing a significant grinding noise from both sides, but sounds more significant from the passenger rear. I've heard that some noise is normal for the first few days or couple weeks, but I'm concerned that the level of noise I'm getting is abnormal.
Should the noise be very obvious for a short while and maybe I'm just paranoid? Or is there something important I should check for?
Old Nov 28, 2017, 04:12 PM
Received 1,384 Likes on 1,317 Posts
Make sure you didnt bend the dust shields as they maybe contacting the rotor. Happens all the time!
Old Nov 28, 2017, 04:27 PM
Gr1m's Avatar
I checked that out, since I remember them getting in the way when I was trying to remove the old rotors, but they look fine - full clearance. I also made doubly sure that the rotors were installed facing the correct way with the slots. I took a picture to show all the dust/shaving from less than 3 miles. Maybe 4-5 stops at about 30mph.
Old Nov 28, 2017, 06:29 PM
Did you go through a proper bedding-in process?
4-5 stops is not a full process.
Just making sure you did the full procedure
Old Nov 29, 2017, 05:36 AM
steve0677's Avatar
Hawk pads can be noisy. Try taking the pads out and putting some high temp anti-sieze compound on the back of them.
Old Nov 30, 2017, 02:32 PM
Gr1m's Avatar
Appreciate the responses, I was able to find the issue! As it turns out, I should have rechecked the work I was confident I did right. If anyone else has this issue: make sure your spring clips that push down on the pads are not installed upside down...
Old Nov 30, 2017, 03:01 PM
kyoo's Avatar
i thought those are symmetrical
Old Dec 1, 2017, 02:01 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
They are left/right symmetrical. They do have a top and a bottom though.
Old Dec 1, 2017, 02:26 PM
kyoo's Avatar
ahhh
Old Dec 9, 2017, 07:32 PM
Timothy Kramer's Avatar
Same issue with autozone pads\rotors? When I got my Evo they supposedly just replaced them.. hasn't been more then maybe 5k miles on the car and I feel like they are already making noise and not feeling "right"...
Old Dec 10, 2017, 06:15 PM
Hiboost's Avatar
That would definitely allow them to shake around in there as you put pressure on the brakes, seen it before opening up brake systems for friend's cars.
S1MPSONS
May 3, 2016 11:38 AM
S1MPSONS
19
Jul 16, 2015 07:51 PM
Fizz Autosports
Evo 'For Sale' Suspension / Brakes / Handling
124
Sep 14, 2009 07:26 AM
CVR Motorsports
13
Sep 10, 2008 01:40 PM
Quick Reply: New Rotors & Pads Grinding
