Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Getting Wheels - Will this fit?
Old Apr 9, 2008 | 09:40 AM
DC2TMike's Avatar
Originally Posted by ommmjido
well either way that size is way too tall for the X
read my #11 post pls.
Old Apr 9, 2008 | 12:37 PM
jd888jd's Avatar
So 265/35/18..is the closest to stock and its better than 265/40/18..
If you go with a 18x9.5 rims, what would be the right size tires for this size rims?
Old Apr 9, 2008 | 01:57 PM
DC2TMike's Avatar
I would go with 275/35 which is .2 inches lower than stock. You can run 265/35 too and its only .4 inches lower than stock.
Old Apr 9, 2008 | 03:10 PM
jd888jd's Avatar
How about the speed rate, how much off you be running if you go for 265-35-18?
Old Apr 9, 2008 | 03:16 PM
HondaFlyBy's Avatar
oooh those are pretty big :/
Old Apr 9, 2008 | 03:17 PM
DC2TMike's Avatar
Its gonna be minimal. Your speedometer would be higher than your actual speed since you're spinning a slightly shorter tire.
Old Apr 9, 2008 | 03:55 PM
RKT SHP's Avatar
so how wide of a tire could you put on the X with rolled fenders and all. would a 295 or 305 be possible with the right of-set
Old Apr 9, 2008 | 08:08 PM
madfast's Avatar
on stock suspension, stock suspension settings (camber), no fender rolling, 265/35 on 18x9.5 wheel is the best bet. tons of people have that combo with no reports of rubbing. 275 may have rubbing issues.
Old Apr 9, 2008 | 08:50 PM
DC2TMike's Avatar
You can run 275/35 on a 18x9.5 rim with no rubbing issues as long as you run 30+offset or higher.
Old Apr 10, 2008 | 03:56 AM
ommmjido's Avatar
read my post #9 pls
Old Apr 10, 2008 | 03:15 PM
RKT SHP's Avatar
does anyon know the answer to my question or has noone but robi explored the limits yet
Old Apr 10, 2008 | 04:40 PM
Speed Element's Avatar
Originally Posted by nebolic
Hi,
I just purchased a set of wheels for the X.
Size
18x9.5 +30
running 265/40
Will this fit?
Cheers,
nebo
it will fit but might look a bit sunken in .. should have gone +22
Old Apr 10, 2008 | 04:52 PM
on what size of wheels? 18x9.5 or 18x10?
You can go as wide as you want but do you really need all of that?
The Japanese tuners must also know something about the benefits of balancing unsprung weight versus the amount of available traction, as they all seem to prefer rather narrow tires. The CT230R performed its record breaking run on 265-wide Yokohama A048 DOT tires
http://www.turbomagazine.com/feature...iii/index.html
Old Apr 11, 2008 | 07:43 AM
RKT SHP's Avatar
I am thinking along the lnes of an 18x10.....I am not looking for this wide of a tire for cosmetic purposes....I do a lot of SCCA driving and if i could get a 295 under this car. i would be a happy man, and I think that would be perfect with a set of slicks or r-compounds
Notanevo302
AWD Lancer (2012 +)
Jun 10, 2017 06:24 PM
jarek0621
Dec 16, 2015 03:06 PM
haulksmash
Nov 9, 2015 07:09 PM
nekkidlad
44
Mar 26, 2013 05:11 AM
Teedub's EVO
19
Aug 6, 2006 04:58 PM
