Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Getting Wheels - Will this fit?
Old Apr 8, 2008 | 11:37 AM
nebolic's Avatar
Hi,
I just purchased a set of wheels for the X.
Size
18x9.5 +30
running 265/40
Will this fit?
Cheers,
nebo
Old Apr 8, 2008 | 11:54 AM
Red Dragon's Avatar
i think it should fit but go with a 265/35 tire. you want to stick with close to stock circumfrance.
Old Apr 8, 2008 | 11:58 AM
nebolic's Avatar
i think stockers are 45, i'm sticking with 18inch and stock is 18. if i go 35, won't that throw it off more?
nebo
Old Apr 8, 2008 | 12:50 PM
madfast's Avatar
nebo
stock is 245/40-18
Old Apr 8, 2008 | 01:17 PM
Red Dragon's Avatar
http://www.1010tires.com/TireSizeCal...bmit&reset=yes
stock is 40
Old Apr 8, 2008 | 02:17 PM
nebolic's Avatar
so i should be cool with sticking to 40?
nebo
Old Apr 8, 2008 | 02:53 PM
StevenStarke's Avatar
stick with 35, try to get a lower offset though, it will be more flush
Old Apr 8, 2008 | 03:28 PM
madfast's Avatar
nebo
for a 265 sect width, no! 245/35 would be closer to stock. unless you want a taller tire...
Old Apr 8, 2008 | 03:57 PM
ommmjido's Avatar
dude there's no such thing as a 265/40/18 tire...... if u really want it to be close to the stock diameter, get 275/35/18.
Old Apr 8, 2008 | 04:23 PM
HornetZ's Avatar
If the Stock wheel is a 18in wheel and it has a 40 series tire (which it is, and it does), and the wheel he is using is an 18in wheel, and you want to keep the Rolling Diameter the same as Stock then I'm gonna go out on a limb and and say that maybe Edit: We should both got use a Tire calculator..lol
As for the second quote ..... Try Looking Here!!
Old Apr 8, 2008 | 04:40 PM
DC2TMike's Avatar
Here it is, stock tires 245/40/18 25.7 inches tall, 265/35/18 25.3 inches tall and 275/35/18 is 25.5 inches tall. You don't wanna go 265/40/18 since that's 26.3 inches tall. Hope that helps.
Old Apr 8, 2008 | 04:41 PM
Red Dragon's Avatar
i swear to god, some people dont think, or dont read. I have included a tire calculator above, its really easy to use. the stock tire is a 245/40/18. a 265/35 is better than a 265/40 tire. a 265/40 tire will work but the diameter will be larger than a 265/35
Old Apr 8, 2008 | 04:43 PM
DC2TMike's Avatar
Yes, these tires are available. Here's the link.
http://www.tirerack.com/tires/Compar...t=All&x=70&y=7
Old Apr 9, 2008 | 02:05 AM
ommmjido's Avatar
well either way that size is way too tall for the X
Old Apr 9, 2008 | 05:49 AM
pltek's Avatar
sorry no harm meant but i would have checked wither they fit before buying
Hi,
Size
18x9.5 +30
running 265/40
Will this fit?
Cheers,
nebo
