Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Offset Discussion:
Old May 21, 2008 | 03:54 PM
  #31
EJxxx's Avatar
Originally Posted by singo
Will 18x10 38 rub on hard conering?
That is alot of backspacing on that wheel. Its stock offset and 1.5 inches wider meaning its going to take up an extra 3/4 of an inch on the inside(~19mm). The 19x10'+35's were confirmed by Works to fit, however I dont know if that was on stock struts. Coilovers would free up some space. Even with a 255/35 it might rub the plastic in the wheel wells up front if your lowered. You should have plenty of room near the fenders so just run a small spacer to help you out there. I would do a 10mm spacer on that +38 and that will make it about as flush as the 9.5 +22's archie and now AGP's car are wearing.
twrtoad
May 12, 2016 03:50 PM
kensuke
92
Apr 12, 2015 10:44 PM
FL_SilverEvo8
Oct 4, 2013 10:22 PM
godzuki
Nov 4, 2011 06:39 AM
xtnct
Oct 7, 2005 08:28 AM
