Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Suspension/Coilover Noise? Rattle?
Old May 24, 2008 | 11:26 AM
DirectorSe7en's Avatar
I just bought these BC Coilovers, now I'm nervous they might be lower quality since there's all this talk about them rattling....
Is there any fix? Does this happen to everyone? What's BC saying about this?
Old May 24, 2008 | 11:53 AM
Mightygnu's Avatar
They are fine, they are great quality.
Old May 24, 2008 | 12:43 PM
mrdecibel's Avatar
Some BCs have noise and some don't? I wouldn't call that normal without an explanation. Just because some may live with a noise doesn't mean its right. The BCs are great for the money, no doubt. However, don't think they should be making rattling noises. Putting a thin layer of rubber between the top and the car should not sacrifice performance. It will help in isolating the whereabouts of the noise. I couldn't live with the noise. But I am here try to assist others in resolving theirs.
Old May 24, 2008 | 08:14 PM
ustcc evo's Avatar
One fix is a decent set of camber plates with a quality upper bearing.
$500-$700 for the camber plates alone.
Old May 24, 2008 | 09:02 PM
danielskshin's Avatar
Did you take out the spare tire and leave in the bolt?
Do you hear the rattling noise when going straight?
My JIC's have pillow mounts, but I don't get any rattling noise.
Old May 24, 2008 | 09:10 PM
Mightygnu's Avatar
Spare tire is in and the bolt is in.
I hear it when going straight, only if the road is in anyway bumpy.
Old May 25, 2008 | 03:58 PM
Mightygnu's Avatar
Anyone else?
Old Jun 4, 2008 | 01:19 PM
JoeyM3's Avatar
did you get this problem solved? if so what did you do? looking to get these when i get an x
Old Jun 4, 2008 | 02:33 PM
Mightygnu's Avatar
Just preload the rear.. noise gone!
Old Jun 4, 2008 | 06:52 PM
mrdecibel's Avatar
How many turns or in/mm did it take to preload? I tried the 7mm preload and nothing. Went to 10 and nothing. Just curious to what solved yours?
Old Jun 5, 2008 | 02:03 PM
sexktten's Avatar
Mine has done it sense I installed them, my fiance says it is because of the pillow mounts... so it must be normal.
Old Jun 5, 2008 | 03:14 PM
Mightygnu's Avatar
Yes, the noise is the pillowball mounts, i preloaded like 7mm and it fixed it for the time being, but the noise is back..
Old Jun 6, 2008 | 09:35 AM
ZK's Avatar
ZK
It's the metal on metal from the upper mount that makes the noise. If it had a rubber upper mount - it would isolate it.
I've had Tein Type Flex, Megans, BC Type BRs and Ohlins which make the clunking sound in the rear. I don't like it but I just ignore it now.
EvoIXPilot
36
Aug 8, 2018 08:03 PM
Dross99_si
13
Sep 16, 2016 10:57 PM
Crazems
Feb 3, 2012 12:19 PM
NelloMorto
Dec 20, 2010 02:58 PM
raytrix
Sep 2, 2010 08:10 PM
