Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Alignment after Coilover install.
Old Jun 23, 2008 | 10:24 AM
heSOshAdy's Avatar
Does anyone have the factory alignment specs? A buddy of mine just installed his BC coils on his X and is trying to get an alignment done, but the shops don't have the factory specs.
I was curious to know what other X owners with coilovers are setting their alignment specs to.
Thanks!
Old Jun 23, 2008 | 01:46 PM
08EvoXGSR's Avatar
The specs are not out yet-I set mine at 0 toe, -0.4 front camber (appox 4.4-4.6 caster) and -1.4 rear camber.
Took a while to get it in....but it drives great!
You shouldn't need fac specs for the software-if you tell them what you want (or have him go back to stock, get a read, then install the BC's).....good luck!
Old Jun 23, 2008 | 04:40 PM
GTWORX.com's Avatar
Yikes, -.4 up front is weak.....for even lightly spirited driving you want more then that. Get the most out of your car!
- andrew
Old Jun 23, 2008 | 05:29 PM
cflango916's Avatar
I'm curious on this as well. I am installing coil overs on mine tomorrow. Anyone else with coil overs installed that have gotten an alignment done yet?
Old Jun 23, 2008 | 05:35 PM
Robevo RS's Avatar
this is my problem too. The alignment is depend on so many things , i dont even want to be involved . Like tire choice, car weight, coilovers , spring rate , the track where you go etc. So i think the best is to leave it for the pro's.
So i think you best bet is Robispec.
Sadly he is not around here so i have to go somewhere else.
Old Jun 23, 2008 | 05:58 PM
is300's Avatar
my ? goes if you purchased a robispec will he be able to supply you with alignment spec or is some secret so people can share his spec
Old Jun 23, 2008 | 06:09 PM
Robevo RS's Avatar
i'm sure, but the custom alignment is always better. Like the mail in ECU flash versus on the dyno ecu flash.
i think anyway, but i can be wrong. I'm a dummy when it comes to alignment.
SO i'm sure some guy's know they alignment numbers.
Old Jun 23, 2008 | 06:42 PM
GTWORX.com's Avatar
If whoever you buy a coilover from can not recommend you an alignment spec, you should not be buying coilovers from them. Period.
That said, some people (like Robi) will have a better recommendation then others, and that's why people go to him and why they have good results.
- andrew
Old Jun 23, 2008 | 07:45 PM
CBRD's Avatar
ill throw my generic alignment specs out...
1/32nd to 1/16th toe out in the front...
0 toe in the rear, max camber front... and rear...
it honestly works for 80 % of our clients, the rest we work with to find a custom spec for.
cb
Old Jun 23, 2008 | 09:00 PM
Mightygnu's Avatar
cb
Sounds good to me!
Old Jun 23, 2008 | 09:22 PM
evox_'s Avatar
I was impressed when my alignment shop came back with the results this weekend:
-1 camber on the front and -1.2 on the rear, with all stock parts...
Old Jun 24, 2008 | 03:29 AM
wartownracer's Avatar
if you ask for a print out of your alignment specs can the machine lie? In other words can the operator of a hunter alignment machine go in and enter some numbers and print them out and give to me just so i will shut up.?
Old Jun 24, 2008 | 06:58 AM
Highwind's Avatar
i went to a shop in pomona that has the alignment specs already in the computer. owner also has a evox.
Old Jun 24, 2008 | 08:22 AM
nebolic's Avatar
running -1.5 camber all the way around.
nebo
Old Jun 24, 2008 | 08:23 AM
cfdfireman1's Avatar
yes
a good operator can move the mirrors or whatever is attached to the wheels and show almost anything on the printout.
