Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Eibach spring plastic tube !
Old Jul 17, 2008 | 03:36 PM
xXEVOloverXx's Avatar
i got my Eibach spring and it came with a short rubber tube cover part of the spring , i should take it out be4 install right? just wanna make sure.ty
Old Jul 17, 2008 | 07:09 PM
Bar's Avatar
Bar
I have a question about Eibachs as well.
Should camber adjustment be made, or will basic alignment do the trick?
Old Jul 17, 2008 | 07:23 PM
GTWORX.com's Avatar
Originally Posted by xXEVOloverXx
i got my Eibach spring and it came with a short plastic tube cover part of the spring , i should take it out be4 install right? just wanna make sure.ty
No, don't take that out. It's there for a reason.
- Andrew
Old Jul 17, 2008 | 07:24 PM
GTWORX.com's Avatar
You need an alignment after installing springs.
- Andrew
Old Jul 17, 2008 | 07:30 PM
Kracka's Avatar
GTWORX is right on both counts.
Old Jul 17, 2008 | 09:01 PM
i gonna install tomorrow and then i do the alignment next week wait for spring to be settle
Old Jul 17, 2008 | 09:02 PM
just did a little research that rubber tube is for springs don;t make noise.
Old Jul 17, 2008 | 10:45 PM
goevox's Avatar
yeah keep the rubber and get an alignment forsure.
Old Jul 18, 2008 | 05:06 PM
Bar's Avatar
Bar
- Andrew
On my VIII, i got springs installed and alignment.
Just heard some people talking about camber adjustments and stuff, didn't think it was necessary.
Thanks a lot.
Old Jul 18, 2008 | 10:50 PM
GTWORX.com's Avatar
Camber adjustments = alignment.
- andrew
Old Jul 18, 2008 | 10:55 PM
Mightygnu's Avatar
- andrew
I don't see how some people don't know this. but there you go!
Old Jul 20, 2008 | 02:22 AM
Hiboost's Avatar
For sure if you replace the springs you need to get the car aligned. Even though Camber is the most noticeable change, it's actually the Toe Out that eats tires for breakfast when modding the suspension. I plan on getting it back to stock Toe settings and leave some of the negative camber in there within reason.
Has anyone got any before and after numbers when just replacing springs so I have an idea of the changes it can make?
homwerk
May 30, 2017 12:25 PM
Spartan716
May 13, 2016 05:53 AM
evolucion
14
May 20, 2008 11:46 AM
evoixdk
Oct 9, 2006 04:01 AM
akinaspeedstars
Apr 2, 2004 02:18 PM
