Anyone know if stock 9 wheels will fit on a 10 ? I've read conflicting posts regarding certain 17's...
17's don't fit unless they are extra special. The front calipers on the X are bigger.
Quote:
Define "extra special"Originally Posted by goofygrin
Quote:
custom made. Like the 16" CCW's buschur runs on his RS over the factory brembos.Originally Posted by spooled_u
If you look at the pic above, you will see that as the rim gets closer to the spokes, the rim curves in towards the hub; therefore allowing less space to fit the 13.8in Brembos. Some 17in wheel designs curve less than the factory Evo IX wheels; thus allowing them to fit over the larger Evo X brakes.
I'm wondering if those 1" wheel spacer kits would do the trick to use just about any 17" wheel?
