Stock Alignment Spec for Evo X???
Trying to run -1 camber up front will chew up your outside edges in no time at all even with just street driving. -2 is a good starting point up front. I was able to get -1.9 front both sides without flipping the bolt.
A good street setup IMHO would be -2 up front with 0 toe -1.2 to -1.5 with a little toe in on the rear.
You got -1.9 in front with stock springs and ride height or lowered which makes more sense?
when you need to calibrate the sensor, the traction control are desactivate? i change the clutch and the dash screen say the traction control are off.maybe i need to calibrate the sensor?? please help
Roen
12
Aug 15, 2013 08:33 PM
1800bigk
Sep 18, 2011 09:53 PM
BIGWING
Sep 9, 2003 08:05 AM
iodine23
15
Apr 16, 2003 10:01 PM
