Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Just got My Eibach's Installed
Old Jan 18, 2009 | 03:23 PM
pbfoot's Avatar
you don't HAVE to get an alignment, I didn't get one on my GTI when I had H&R super sports installed and saw no determent in handling or tire wear-though I would get one to be safe.
Old Jan 18, 2009 | 04:03 PM
lowkey's Avatar
Registered User
Like others have said, if the toe is off you will kill your tires in 10k miles or less because we have soft rubber on our cars. An alignment is $100, far less than a set of tires. Why take a chance?
I just installed a set of MR Bilsteins with WORKS springs on Saturday and I’m taking it for alignment on Monday.
Old Jan 18, 2009 | 04:41 PM
beetle_orange's Avatar
^could be the first gsr with mr struts. any pictures? this was my plan with swift springs until plans got derailed.
Old Jan 18, 2009 | 11:29 PM
Fishstix's Avatar
I don't mean to hijack this thread, but this is relevant.
If one is looking to only do a drop, but on an aggressive offset (+17), is a fender roll along with the Eibach springs sufficient to house the wheels?
Old Jan 19, 2009 | 08:54 AM
^i think you are going to need a lot of negative camber.
Old Feb 12, 2009 | 10:42 PM
laramsfreak's Avatar
I should have gotten a proper alignment a lot sooner! Took it to Lake Tahoe (I'm from Southern California) and when I got back, I noticed that the inside edge of my driver side front tire was basically gone. Weird that it's just that one tire though.... So I took it for an alignment at the dealer, rotated the tires around and it still wore out the same wheel, although it was a lot lighter wear. From the work order, it says
"Front: Left ---- Toe Before = -0.17deg, Toe Actual = -0.03deg"
"Front: Right --- Toe Before = -.019deg, Toe Actual = -0.05deg"
"Front --- Total Toe Before = -.036deg, Total Toe Actual = -0.08deg"
"Rear: Left ---- Toe Before = 0.22deg, Toe Actual = 0.10deg"
"Rear: Right --- Toe Before = -.004deg, Toe Actual = -0.08deg"
"Rear --- Total Toe Before = 0.18deg, Total Toe Actual = 0.19deg"
Well, I have another alignment scheduled tomorrow morning to figure out what else to do. Also, the camber I have now reads at "-1.2deg". Should it be "0"?
Old Feb 12, 2009 | 11:46 PM
kitw's Avatar
Originally Posted by CatalystGod
The EVO generally comes with a negative camber setup for performance around corners. My stock ADVANs wore out on the inside edge exactly at 12,000 miles. It really comes to what you want. With my new winter tire setup however, I am planning on getting a zero camber setup.
Camber doesn't wear tires nearly as fast as toe.
Old Feb 13, 2009 | 07:39 AM
lowkey's Avatar
Registered User
Ask for a custom alignment and be willing to pay extra so that the tech can take more time with your car. Your fronts look consistent, but I would not be happy with the rears. Do a search for alignment specs. My personal preference is 0 toe and 1 deg negative camber all around. It’s highly unlikely the tech will get both sides exactly the same, so don’t fight it if it’s plus or minus 0.03 either way.
Old Feb 13, 2009 | 06:40 PM
WAM's Avatar
WAM
Toe is really easy to measure. Don't any of you DIY?
Old Feb 13, 2009 | 10:40 PM
jackygor's Avatar
Since we are talking about alignments in this thread, I want to ask a question. Is it better to get an alignment at the dealership or where ever? The reason I ask this is because I heard that the dealership can collaborate the steering wheel or something?
Old Feb 14, 2009 | 06:32 PM
lowkey's Avatar
Registered User
After the alignment just check your steering wheel spokes to see if it's straight when your wheels are turned staight ahead. If not, let them fix it. As for shops, ask around for someone good or a good shop in your area. I have had good luck with a National Tire and Battery shop close to my house. Never had a Evo alligned at a dealership but had it done for a Toyota and it was a disaster. One set of tires later the NTB shop got it right.
Old Feb 14, 2009 | 07:54 PM
jackygor's Avatar
Thanks for the answer
Old Mar 1, 2009 | 08:45 AM
Cornerstrike's Avatar
More pics please!
