Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Camber bolts??
Old Nov 19, 2008 | 09:28 AM
dollar99's Avatar
Camber bolts??
My car is currently at the shop getting an alignment after being lowered by Eibachs. The mechanic is telling me that the front/left wheel camber is at -2.5 and I will need new bolts ($35 for the bolt + $78 in labor) to get it to -1.5. He said the other wheels are fine. Are they trying to rip me off or are they doing something wrong?
Old Nov 19, 2008 | 10:03 AM
goofygrin's Avatar
::cough:: bull**** ::cough::
On the top strut mount bolt, there is a white dot of paint. You put it toward the strut for the stock -1 and away from the strut to get -2.
I think you should leave the camber at 2.5. Car handles a lot better with it! Leave the toe at 0 and you'll see minimal tire wear.
Old Nov 19, 2008 | 04:00 PM
dollar99's Avatar
thought so, thanks.
Old Nov 22, 2008 | 04:17 PM
salagahle2000's Avatar
Find another shop
Old Nov 22, 2008 | 06:03 PM
Eurorcr's Avatar
Anybody know of a company that makes or plans to make front camber plates that fit the stock strut assembly?
Old Nov 24, 2008 | 09:07 AM
smgevo's Avatar
Vorshlag is working on two styles. A 60mm coilover design and a stock spring fitment. Contact them or maybe they can post here about them if they see this thread. Good stuff.
Old Nov 24, 2008 | 09:17 AM
meckert's Avatar
The stock strut bolt will give you the designated camber at a stock ride height. You maynot be able to get the camber you want with the stock bolts on a lowered car. You get more camber when you lower a vehical. Camber bolts are 19.99 a set and shouldn't cost more then a basic alignment to set them up--nothing additional.
Old Nov 24, 2008 | 03:50 PM
txfoster's Avatar
Got mine done at Cobb in Plano and they put -2.5 on all 4 corners, luv it!
They have an excellent alignment system.
